ZAX1
ACE Pump removal or bypass, help needed | |
I have issues with the anti roll bar, leak ,
currently popped 2 ACE Pumps and belts as I had the dreaded noise of a failed pump, lots of play in the pump pulley,
I not sure where the issue is but as I don't really need this feature, I am looking to bypass the ACE pump.
I have seen that you can just use a shorter belt which I have done, however I can't seem to see the diagram to bypass the pump, if anyone can help.
Failing that, I could remove the pump and does anyone know if I can just replace the space with a same sized pulley so that I can just run without the pump, but of course there will be a pullery spinning in its place.
All help is appreciated. thanks in advance!
HSE Sport 2.7 TDV6 2009
Tue Apr 09 2024 8:38pm |
