Home > Technical > Park break release |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
First.
Fri Apr 05 2024 8:21pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 281 |
it's chocked now with hand break off
Fri Apr 05 2024 8:23pm |
left the park break off for two days had the wheel off breaks are free think the park break is seized on
Sun Apr 07 2024 2:55pm |
I’d take the disc off.
Sun Apr 07 2024 3:36pm |
thanks Andy that what I was thinking take disc off |
Sun Apr 07 2024 3:48pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
I doubt pulling the emergency release will help if it's the actual mechanism in the wheel unit itself that is seized. 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 07 2024 8:40pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 424 |
Agree with @RRSTDV8, the levers on the shoes are likely seized. Banging on the outside of the drum area is about your only hope till you get it to free up enough to get the rotor to turn. Once the rotor can turn you can get the adjustment window aligned to back off the star wheel adjuster. Had to do this not too long ago on a Disco 4, it’s not fun, but not impossible. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Apr 08 2024 2:23am |
is the adjustment window the little hole in the hub ?
Mon Apr 08 2024 6:25am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4855 |
Yes, but not going to be of much use if you can't turn the disc to line it up with the adjuster yet, as suggested just give the disc a few good whacks with something like a copper mallet or dead blow hammer.
Mon Apr 08 2024 8:29am |
I did try to smack it with my heavy rubber mallet will have another go at weekend
Mon Apr 08 2024 3:07pm |
Sat Apr 13 2024 11:23am |
Need to have the Steering Angle Sensor recalibrated. This takes some sort of diagnostics capable of doing this. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Apr 13 2024 8:06pm |
managed to sort it out with a hawkeye like you said it needed re calibration doing on it |
Sun Apr 14 2024 7:42am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 337 |
Only use the handbrake if on a ferry or channel tunnel. Always listen to old people or when they die you will live on in ignorance.
Mon Apr 15 2024 6:28am |
