Home > Technical > Park break release |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 281 |
thaing was it wasn't even on for a year I only use the the hand brake if parked on a slight incline
Tue Apr 16 2024 6:11am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
If you don't use something mechanical other than very occasionally then it's no great surprise that it can seize when used. Best advice with the EPB is to use it every time - use it or lose it, basically.
Tue Apr 16 2024 9:37am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
For some stange reason I have got into the habit of using the park brake every time when out and about, but when the car is parked in the garage I never apply it, I do however clean out the drums etc. and check/adjust it every service, proably tempting fate now but never had a issue yet.
Tue Apr 16 2024 9:59am |
had the old girl back from mot all it failed on was front ball joint rubber split
Sat Apr 20 2024 9:23am |
