Home > Maintenance & Modifications > Heated Steering Wheel Issue
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Hi All
I have an 2012 Range Rover Sport Overfinch , with a Heated Steering wheel, However when I pull the Heater switch on the steering wheel it lights up for a second then goes off, then nothing.
Is it possible that the steering wheel clock is causing this or is it more sinister? Question
Ta Muchness
Post #640532 Tue Mar 19 2024 3:44pm
There is a small control module in the steering wheel, could be that, have a heated wheel here somewhere will dig it out and post a picture, downside is, if that does happen to be your problem L/R do not supply it separately from the wheel or never used to. Have you checked fuse No. 20 behind glovebox just to be sure? red 10 amp.
Post #640537 Tue Mar 19 2024 10:06pm
