Home > Maintenance & Modifications > Heated Steering Wheel Issue |
The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 27 |
Hi All
Tue Mar 19 2024 3:44pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
There is a small control module in the steering wheel, could be that, have a heated wheel here somewhere will dig it out and post a picture, downside is, if that does happen to be your problem L/R do not supply it separately from the wheel or never used to. Have you checked fuse No. 20 behind glovebox just to be sure? red 10 amp.
Tue Mar 19 2024 10:06pm |
