Home > My Range Rover Sport > 2021 P400e Autobiography Dynamic |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S |
Thu Mar 14 2024 11:35pm |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 95 |
First impressions after a few days ownership.
Mon Mar 18 2024 11:36am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1750 |
yes, should move away quickly as using electric motor when crawling or pulling away.
Mon Mar 18 2024 12:56pm |
To be honest, not tried pure EV mode yet (keep forgetting to press the button).
Mon Mar 18 2024 1:00pm |
Do a test in EV mode, there is a common problem with the battery heater and if you have that then you will not be able to run in EV mode without the engine starting.
Mon Mar 18 2024 1:06pm |
Just tried EV mode on a moderate journey - 25 miles of country A and B roads
Mon Mar 18 2024 2:48pm |
A little bit of engine then! Pure EV records as 250+ mpg! 2023 P440e SE Dynamic on order -cancelled
Mon Mar 18 2024 3:45pm |
Yeah, ran out of juice about a mile from home. It also engaged the engine for a bit after emerging from junctions.
Mon Mar 18 2024 3:50pm |
especially pulling out of junctions or entering roundabouts etc
Mon Mar 18 2024 5:48pm |
The hybrid should be using the electric motor, mine certainly does. 2023 P440e SE Dynamic on order -cancelled
Mon Mar 18 2024 6:06pm |
Is this boot alignment normal, or does this need to be corrected? I saw the same dropped boot on my Evoque and had it raised to line up.
Mon Mar 18 2024 7:22pm |
I manged to get the charging to complete properly now.
Wed Mar 20 2024 9:21am |
Charging has gone back to showing "Initializing" again at the end of the charge cycle. At least it charges up all the way before it does that though. Unlocking/Locking the doors doesn't do anything in this state as the charge unit itself is in an error state.
Fri Mar 22 2024 11:32am |
What artificial engine noise? I only have the real one! 2023 P440e SE Dynamic on order -cancelled
Fri Mar 22 2024 1:24pm |
