Home > Faults & Fixes > P049C-00 (27) Exhaust gas recirculation - B - Excessive flow |
Milstad Member Since: 31 Mar 2013 Location: Peterborough Posts: 4 |
Update on EGR issue. I found Halfords Autofix quite helpful and tested the wiring on the 5 pin plugs - wiring from ECU to EGR plug is all good. Left EGR valve still showing 0% Actual, vs varying Commanded values.
Mon Mar 04 2024 1:31pm |
