Home > General (L494) > Infotainment Audio, SatNav & Bluetooth Failed |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 13 |
The amp is definitley under there.
Sun Jan 21 2024 10:27pm |
Garrfield Member Since: 20 Dec 2023 Location: Wokingham Posts: 33 |
Thanks, had no idea the seat has to come out first! This guys is very useful thanks for the info Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Sun Jan 21 2024 10:49pm |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 152 |
Hi, I had the same problem in my 2014 AB (with the 1700W sig-ref system) a few months ago.
Mon Jan 22 2024 3:07pm |
Thanks Punkawallah! I did wonder what that grey box was for and I did check to see if all the fuses were good there to. Yep water ingress on that side and I have a feeling it has blown my diff module tucked away above the grey fuse box, certainly a smell of burning from it when I took it out yesterday.
Mon Jan 22 2024 3:59pm |
I think I used the handbook and a little guesswork to work out which fuses did what. From memory the ones you want to remove are 10A and 15A fuses, you'll need some long-nose pliers! Good luck... 2013 L494 V8 s/c Autobiography Dynamic |
Tue Jan 23 2024 3:21pm |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 177 |
Check your sunroof drains immediatly , just above door aperture on rear seats.
Wed Jan 24 2024 12:47pm |
Thanks, I didn't have the handbook but managed to download one and you are spot on. I will try that at the weekend. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Wed Jan 24 2024 3:29pm |
Thanks for that. I will check at the weekend. It doesn't seem to be getting any worse considering the rain we have had this week and the boot area seems to be dry now! Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Wed Jan 24 2024 3:31pm |
Would you know which way or the route the drains take ie from above the door aperture the go down and out somewhere, would the out let possibly be blocked is my thinking? Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Wed Jan 24 2024 7:32pm |
You need to blow some compressed air through the drain from the top to test if there blocked/working - you need to pop the long trim off the roof to edge of the sun roof- use a plastic tool and just the pop clips off from back of the car to the front - you can then see the drain hole.
Wed Jan 24 2024 7:57pm |
Thanks. Just reading up and I have the full pano with the electric roof. Seems the drain is in the sunroof cassette rear. The consensus is that the steel nipples that the hose attaches to rot away. So I intend to check under the roof lining first, then fully retract the sunroof and pour a little water in the cassette which should drain away or it will end up inside the car. Update to follow, suns out tomorrow so be a good chance to try. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Wed Jan 24 2024 8:04pm |
Yes that’s it matey. Common unfortunately on the pano roof cassette another bad design :/.
Wed Jan 24 2024 8:10pm |
Checked exactly where you suggested and the hose is not connected as the steel nipple has rotted away so the source of the problem is found but not the solution yet! Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Tue Jan 30 2024 10:35pm |
Karl did you find those links? Need help now to fix this before the inevitable rain comes back! Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1 Previous: 2007 3.6 TDV8 200k miles (The best, gone but not forgotten) |
Tue Jan 30 2024 10:37pm |
