Home > General (L494) > Infotainment Audio, SatNav & Bluetooth Failed |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 177 |
Here you go sir - get a car cover whilst your getting the repair done if the car is parked outside overnight
Tue Jan 30 2024 10:47pm |
Garrfield Member Since: 20 Dec 2023 Location: Wokingham Posts: 33 |
You sir are a star that looks a relatively easy job and your way means no need to remove the lining. In reality how long did it take you? Also where did you get the bungs from, guess I could get some from Halfords or the like? Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Tue Jan 30 2024 11:02pm |
Hi yes eBay/amazon - takes about an hour each side - just undone the rubber seal and unscrew the interior grab handle this will give you some movement in the headlining to get your hand in to reattach the drain hose
Tue Jan 30 2024 11:22pm |
Thanks again Karl. One hopefully final thing, do you know exactly where the outlet is? I know it's around the rear wheel arch somewhere but as I work in quite a muddy site I would like to check that it is not blocked at the outlet end. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Thu Feb 01 2024 10:04pm |
Rear wheel arch just behind the wheel outlet is. |
Fri Feb 02 2024 12:10am |
Thanks again Karl. I have just read through another post of yours I found elsewhere, very useful and informative.
Fri Feb 02 2024 11:29am |
Always happy to help sir šš»šš»
Fri Feb 02 2024 11:32am |
Hi Karl
Sun Feb 11 2024 11:49pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 226 |
I think I have the same problem, on both sides, however I'm struggling to get the headliner down far enough to see. Seems like the interior lights by the grab handles are holding up the liner. I cant see how to get them off. Anybody have any suggestions? RRS HSE Dynamic SDV6 2014
Mon Feb 12 2024 12:51pm |
Have you undone the 2 bolts that hold the handle? You can get a small torch in to see the connection but if it is broke off the pipe will be easy to grab and slide out. Current: 2014 4.4 TDV8 Autobiography 110k miles......will it make the 200k like the Boss did1
Mon Feb 12 2024 1:44pm |
Take off the outer rubber weather seal that runs along the door aperature. |
Mon Feb 12 2024 2:57pm |
Thanks for the replies, I had already removed the grab handle, the rubber door trim and C pillar trim, but still struggling. Any suggestions how to detach the courtesy light? I think that will give me more access for my less than small hands.
Tue Feb 13 2024 11:13am |
Tue Feb 13 2024 11:14am |
Not sure about the light, my hands are small enough to get in there. But, save yourself the bolt drilling and do as I did. Buy the pack from the link below it comes with threaded tube, 4mm nuts and washers etc. Worked a treat for me. This is M10 as you will find when you drill out the old stub it is leaves a 10mm hole. A couple of small pipe clamps and that's it. No need to even cut the pipe down, perfect length.
Tue Feb 13 2024 11:57am |
