Home > General (L494) > Hard brake pedal, car won’t start off button |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
As there are quite a few pipes, check valves, connections etc. in the vacuum system is it worth trying to test the vacuum system for leaks in someway with a vacuum test gauge, as the stop/start valve appears to be part of that system as well, before you start changing to much, only a suggestion.
Wed Jan 24 2024 9:43pm |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 62 |
Yeah this is something I am hoping to do.
Wed Jan 24 2024 10:51pm |
