Home > General (L494) > Hard brake pedal, car won’t start off button |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 62 |
Started first time this morning no problems. Probably 0 degrees over night. Clearly them few extra degrees drop in temperature make a big difference for some reason. |
Sat Jan 20 2024 2:50pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 435 |
You press the start button twice? I only hold the brake and press start once for a couple seconds. It decides how much time it needs to start and fires up every time. Pretty much how I start all keyless start cars.
Sat Jan 20 2024 5:10pm |
I press ignition button once (foot off brake) all lights come on dash car primes itself. Then foot on brake, press button second time car starts. Holding button in on second press makes no difference to me. |
Sat Jan 20 2024 5:19pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4874 |
If I understand correctly press the button once with foot off the brake pedal, ignition comes on and vehicle checks the system for faults etc. once completed, foot on the brake pedal and press the stop/start button again vehicle should start, no need to continually hold the button, the lower the ambient temp the longer the delay the before it will start cranking once the button is pressed due to the glow plugs/cold start system having to do it's thing, with my L320 sometimes I do the check, sometimes I don't bother, no delay though because it is petrol so probably what may make that difference.
Sat Jan 20 2024 10:07pm |
This is the exact process I follow, but as above when the second press is initiated (with foot on brake pedal) the ignition then goes off again (as if you didn’t have foot on brake).
Sat Jan 20 2024 10:33pm |
Have you had the codes read to see if it has a fault registered, like possibly a failed glow plug or two.
Sat Jan 20 2024 10:42pm |
This is from the L320 manual, nothing about pushing the start button twice:
Sun Jan 21 2024 3:40am |
Simple really, if you want the vehicle to do a system check first before starting, press the button once to switch ignition on without pressing the brake pedal to allow time for the check, if you then want the vehicle to start apply the foot brake and press the button again (hence pressing it twice) hopefully the vehicle should then start. If you are not bothered about the system check and just want to start the vehicle, just get into it, apply the foot brake and just press the button.
Sun Jan 21 2024 5:45am |
No error codes logged on car.
Sun Jan 21 2024 3:38pm |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 375 |
When my car eventually refused to start at all the recovery guys checked out the battery and systems. There were no fault codes and battery was fully charged. As said before the garage eventually found a poor connection somewhere under the car but seemed unable to give me a clear explanation. A couple of weeks later the problem returned. Tim
Sun Jan 21 2024 6:13pm |
I will have to double check some of the power cables under the car.
Sun Jan 21 2024 8:18pm |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 13 |
Something to consider.
Sun Jan 21 2024 8:36pm |
Thanks for the info.
Sun Jan 21 2024 10:43pm |
Mac35 Member Since: 15 Dec 2023 Location: Angus Posts: 22 |
It’s not a system check, a pressure reading from the ABS pump tells the ECU that the pedal in depressed and then allows the car to start. Not the brake switch like most cars. The pedal goes hard due the stored vacuum being used up as you press the pedal. It would seem the pressure sensor in the ABS pump is simply not seeing enough pressure for whatever reason, to allow the car to start. |
Wed Jan 24 2024 11:52am |
