Home > Maintenance & Modifications > 2.7 Upper sump gasket replacement |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Have you got the workshop manual? Be worth downloading it if not. 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 15 2021 7:14pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
Remove fan and aux belt
Mon Mar 15 2021 7:41pm |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 |
Awesome, so it comes out the top?
Mon Mar 15 2021 9:28pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
From memory, the front diff has to come out to lower the crankcase down |
Mon Mar 15 2021 9:43pm |
Wondering if the crank case can be lowered just enough to slip the new gasket in, but now problem dropping the diff if I need to. |
Mon Mar 15 2021 10:20pm |
I’ve got it out without removing the diff.
Tue Mar 16 2021 12:03am |
That's good news. I think I am going to start again from scratch with timing belt and oil pump off, then crank case off, then remount the pump and time it up then crank case back on with new gasket to seal from below properly.
Tue Mar 16 2021 6:10pm |
personally I wouldn't remove the oil pump.
Tue Mar 16 2021 6:38pm |
Been working on this today. I can't say it was an easy job, but I guess that is to be expected!
Sat Mar 20 2021 10:22pm |
A further note on this.
Thu Apr 01 2021 9:47am |
paul_wood Member Since: 17 Apr 2021 Location: Hertfordshire Posts: 8 |
Hey! I have a disco 3 and notice this thread may be applicable.
Sat Apr 17 2021 8:05pm |
Not sure ill get down to Herts in a reasonable timeframe to be of any help, but it sounds like youve made all the right progress in getting the oul pump out so its not such a big job from here.
Sat Apr 17 2021 10:50pm |
Fantastic! Shame you can’t be around but what you’ve sent is already making me feel more comfortable about moving forward with this, and so I look forward to any more advice you can offer, much appreciated, thank you! |
Sat Apr 17 2021 11:26pm |
No problem at all.
Sun Apr 18 2021 10:35am |
