Home > Maintenance & Modifications > 2.7 Upper sump gasket replacement |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 |
Sump removal
Sun Apr 18 2021 11:15am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8867 |
Wow, a nice detailed write up. Confirms to me everything I need to know about the job. And why I pay a nice man to do things for me!
Mon Apr 19 2021 8:26am |
paul_wood Member Since: 17 Apr 2021 Location: Hertfordshire Posts: 8 |
Wowza Thank you so much! That’s super duper helpful I actually feel much more confident now! I’m tackling this evenings and weekends around my long a*** job! |
Wed Apr 21 2021 8:56am |
Keep me posted. If anything comes up along the way, no worries with you asking here or dropping me a message and I'll do my best to help out.
Wed Apr 21 2021 7:08pm |
Already in the thick of it. The steering link was unbolted and the wishbone was unbolted on one side all fine, on the other side the upper wishbone nut came off easy enough but the joint refused to come out. Hit it a bit hard and it came out but I think I the thread on the ball joint :O
Wed Apr 21 2021 7:19pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
It’s ok if it spins |
Wed Apr 21 2021 7:34pm |
Thanks!
Wed Apr 21 2021 9:32pm |
Humm. I don’t recall when I did the front.
Thu Apr 22 2021 9:53am |
Glad you’ve got so far
Fri Apr 23 2021 7:41pm |
Oooookay. Just got time to carry on. Managed to get all the bolts out the prop.
Sat May 01 2021 2:32pm |
I struggled getting the driveshafts out too, and gave up.
Sat May 01 2021 2:51pm |
Persistence is the only way. They are designed to come out. Continual sharp tugs and a good pair of gloves to save your knuckles when it suddenly comes out.
Sun May 02 2021 9:32pm |
Still no luck getting them free. Looks like the O/S extension tube has been cemented on to the diff.
Sun May 09 2021 8:53pm |
I think you need to remove the air Con compressor 13mm bolt on the passenger side. You need a UJ joint for this. (maybe this is the long one you talked of)
Mon May 10 2021 9:58am |
