![]() | Home > Maintenance & Modifications > Suspension Knocking! A Fix. |
The following has been submitted by member Voice of Reason - A big thank you.
All customers whom have had this update and in some cases the bushes have since reported total happiness with noise levels. It is also worth noting that those of you that have had the bushes already should seek this update immediately as it is likely the issue will return as your replacement bushes bed in. Regards VOR 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! Last edited by Very Annoyed on Wed Jun 20 2007 8:21pm. Edited 2 times in total |
faria Member Since: 03 Feb 2007 Location: UK Posts: 6 ![]() ![]() |
Hi all nice forum i'm glad i found it thank you .
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
faria join the |
this is realy sad mate. i have made the Guy Salmon service manager give a full report in writting that they did found a Suspension Knocking and Land Rover refused to deal with it. so now i will take them to court and if i can i will contact TOP GEAR so they can put it on tv so the all UK can see how LAND ROVER are a b....of ff are sick people. about 3 weeks ago i read a magazine about cars and they rate all uk car manafactures from 1 to 10 on the custmer service and i didn't came as a surprise as LAND ROVER was at the bottom ![]() see you all i'm goind for a drive with my RR but i will drive it no more then 10 MPH so i don't get sick ![]() |
faria, do waht i did with my old one, turn the stereo up so that you cant hear the dam knock until you get it fixed, i managed to get it fixed in the end, and i plan to get this new one fixed |
hi mate did you get the old one done ?? how and how are you intending the get your new one done?? ![]() |
Thanks to Doc's fix, ie the part numbers for the parts required to sort out the problem plus the dealer also fitted a new antiroll bar, the new car has exactly the same knock so it will go back to the same dealer to get it sorted, and i wont accept it cant be sorted |
[quote="ENVOY"]Thanks to Doc's fix, ie the part numbers for the parts required to sort out the problem plus the dealer also fitted a new antiroll bar, the new car has exactly the same knock so it will go back to the same dealer to get it sorted, and i wont accept it cant be sorted |
sorry mate my dealer is in Stafford, but that shouldnt matter, they should still sort it out for you
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
Just got mine back from the Dealer.
