![]() | Home > Maintenance & Modifications > Removing the rear door door-card |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
I was changing the puddle lights in the doors. All went well until the rear left door. As I pulled the lamp out of the door, the wire came loose and flicked back inside the door. I can just feel it with a finger in the aperture so I think I'll need to pull the door-card away at the bottom to be able to get the wire back through the aperture.
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Hello mate,
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
Or make a small hook out of some wire and go fishing ! i always keep a metal coathanger int he garage for these occaisions |
Alternatively there are 2 screws that once un-done will allow the whole card to be removed.
Popped out to the vehicle at lunchtime. Used a small knife to lever the bottom corners of the door-card away. 2 clips "popped" and I was able to push the wiring back through the aperture. The wire appears to be shorter on this door than the others for some reason. A gentle but firm push on the panel reconnected the clips and I've got a working light on that door again. Total time: 1 minute. |
Good effort! That's your rear screen demister and puddle lights sorted. You'll be changing your diff/transfer box oils next |
Hmmm, not sure I'd go that far kav! |
