Home > Technical > How to fit new wishbone (lower arm) and track rod end
ShooterNeil
Why do you have to loosen/push back the drive shaft
Post #385237 Tue Jun 11 2013 9:02pm
flack
ShooterNeil
Because you have to move it out of the way so the bottom ball joint has enough room to come out when removing the lower arm, otherwise it hits the drive shaft.
Flack Thumbs Up
Post #385273 Wed Jun 12 2013 9:33am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
As Flack said Thumbs Up
It is possible to get the ball joint out without removing the driveshaft but it's quite fiddly and is more grief than just pulling the shaft out.
Kav Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #385275 Wed Jun 12 2013 10:16am
ShooterNeil
Thanks Thumbs Up
Now if I just changed the rear bush would I need a press or is it a wast of time and a pain in the ass
Post #385330 Wed Jun 12 2013 7:11pm
kav1187
I've got a press and still chose to change the whole thing. Depends on how much youre willing to spend on it really.
Remember the ball joints aee also a common issue so it wouldn't be a bad idea to swap them too. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #385332 Wed Jun 12 2013 7:30pm
ShooterNeil
That's what I was thinking but cheaper is not always better so the new full arms will be going on
I can get the lower arms for £125 each LR want £190 each and from what they told me there the same but in a different box
Post #385338 Wed Jun 12 2013 8:17pm
ShooterNeil
Rear bolt is stuck fast what's the best way to cut it off as after an hour of wd40 a hammer and lots of wiggling it just won't move Big Cry
Post #390084 Fri Jul 26 2013 9:57pm
Disco_Mikey
9 inch grinder. Cut the arm off so you can get the grinder back in to cut through the bush and bolt Thumbs Up
Post #390090 Fri Jul 26 2013 10:41pm
ShooterNeil
Thanks Disco_Mikey
Well had to cut 2 bolts off change and change track rod ends in the end
Last weekend I did the front ABR Bushes nice orange polybushed
This weekend lower arms / track rod ends
I am NOW RATTEL WOBBEL AND KNOCK FREE
Happy days time for a lot of Beer
Thank god for the HOW TO DO
NEIL
P.s also have a nice blue painted under tray lol after having to cut 5 bolts off that Sad
Post #390225 Sat Jul 27 2013 7:15pm
ShooterNeil
Time to start all over again lol 8 years on and the 3 RRS 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #606891 Sun Nov 22 2020 10:10pm
