Home > Faults & Fixes > How long to replace water pump L320 V6 |
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 493 |
Pretty easy job really. Drain the coolant, remove the cooling fan, loosen the bolts on the water pump pulley, remove the belt, remove the water pump pulley, remove the water pump, clean the mating surface, reverse back together. 1-2 hours should do it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Sep 14 2024 9:38am |
