Home > Maintenance & Modifications > Roof break light - remover? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4887 |
Sun Jul 14 2024 4:14pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 314 |
Andy - When you say "sadly done from outside" are you referring to having to remove all the trim in the boot upper section before I can get to take off the spoiler? If so, dose the trim simple pull off i.e. held on with clips? Andrew Kennedy |
Sun Jul 14 2024 6:19pm |
No trim removal required.
Sun Jul 14 2024 6:56pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4934 |
Easy as.
Sun Jul 14 2024 9:28pm |
Well. thanks both for your input re removing the parts for getting at the roof brake light - seems my car is not fitted out as a standard 2006 model?!?
Mon Jul 15 2024 2:10pm |
rear cols procedure carefully.
Mon Jul 15 2024 4:04pm |
The penny has dropped!! It doesn't help being dyslexic. I'll sort it tomorrow. Bastille Day hear in France Andrew Kennedy |
Mon Jul 15 2024 4:16pm |
