Home > Technical > RANGE ROVER/DISCOVERY WHEEL ALIGNMENT SPECS |
ozwiz Member Since: 27 Jan 2009 Location: Queensland Posts: 10 |
Alignment/tracking/balancing is 3 different issues.Are your 22's aftermarket and did they come with the hub locators? Wheel wobble is seldom a geometric issue. |
Fri May 28 2010 7:08pm |
NeilN Member Since: 29 May 2008 Location: Durban Posts: 21 |
Ozwiz - thanks for the good advice - I'll rotate the wheels this weekend.
Sat May 29 2010 8:50pm |
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 |
Is my dealer likely to be willing to set my wheel alignment up on my new car as above, or are they obliged to set it up as per LR's instructions? Won't there be talk of waivers, disclaimers and warranties? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Sun May 30 2010 9:27am |
Preacher Member Since: 19 Aug 2009 Location: NE Victoria Posts: 12 |
[quote="ozwiz"]PB,since you asked so nicely,here are the guidelines for your wheel alignments.
Sat Aug 07 2010 9:17am |
Mountain goat Member Since: 17 Nov 2013 Location: Malvern Posts: 1 |
Bernie,
Sun Nov 17 2013 11:02am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
I've had my wheels aligned today due to some slightly uneven wear (N/S rear outer wear & O/S inner wear) & they were setting them to 2.7TDV6 spec (mines a 3.0TDV6). The only figures the garage have are for the earlier 2.7. Does anybody know where these figures that AG09 quoted came from? Russ. I'm in the shed, I'll be back in the real world in a minute. |
Thu Feb 19 2015 6:57pm |
Mullinsman20 Member Since: 14 Nov 2023 Location: North Carolina Posts: 1 |
Not sure if your still around...but was looking spec on an 08 LR3...i have the 3" johnson rods along with 24" rims & 33" tires. Ever since i had a shop align it...it seems to feel like my tires are sitting like a "V"....literally will hug a groove in a road and i feel like im constantly pulling one way or the other. Also...getting scrubbing now as where before I only did if i was close to locking the steering wheel on either side....CAN YOU PLEASE HELP WITH SOME SPECS that I can take with me? Thank you in advance sir....email is....... mullinsman20@gmail.com
Tue Nov 14 2023 1:16pm |
jono123 Member Since: 28 Apr 2024 Location: oxford Posts: 2 |
Hi Bernie, Could you please advise the settings you would advise for mostly motorway country lane driving for a l322 2002 petrol with 255/55 19 Pirelli. also the psi and process with air suspension not to sure as dealer cannot lock height as cpu fuse removed due to battery draining.. Last set of continental tyres lasted less than 6 months before down to radials on inside edge and dirt on seized adjustment nuts suggest never really set right.. Thanks in advance. |
Sun Apr 28 2024 7:23pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
I think you might be being a little optimistic in getting a response, as looks like the guy's last post was 14 years ago.
Sun Apr 28 2024 10:21pm |
Thank you and a good point- nonetheless I was hoping someone may know from experience if what bernie mentioned for the same size tyres on the the Sport is applicable to the l322. the point he made more than a decade ago about even dealerships and tyres companies just applying software recommendations as the least effort rather than what may be optimal still seems to hold true.. |
Mon Apr 29 2024 10:09am |
