Home > Faults & Fixes > Ace pipes replaced (pics) now juddering |
Tom Davison Member Since: 19 Oct 2022 Location: Norfolk Posts: 15 |
Yes it looks a very smart job, and presumably opens up the pipe replacement to a more DIY solution rather than body off job? |
Sat Aug 19 2023 7:48pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 345 |
While we have so many interested people on the thread have i not heard of removing the pump ,fitting a shorter belt to disable the system. What about warning lights.
Sun Aug 20 2023 7:46am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4346 |
ARC pipes are not body off to replace
Sun Aug 20 2023 8:06am |
Quote
Sun Aug 20 2023 8:12am |
Is that a “not a body off, but still need to lift?” There’s no way I could get my pipes in on the 5.0 without bending the pipes, lifting the body a few inches or cutting them, the bends in the pipes exceeded the space available. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Sun Aug 20 2023 6:38pm |
Cchewy Member Since: 16 Apr 2024 Location: Surrey Posts: 5 |
Hi All, Does anyone know the pipe size of the ARC pipes. Looking to pick up some compression joiners and should imagine a 10mm coupler will do but thought as you have done this job before you could possibly know for sure the size…. Thanks in advance. |
Sat Apr 20 2024 4:37pm |
It’s been quite a while but I think it was 10mm. 2012 5.0 SC AB
Sat Apr 20 2024 5:27pm |
Thanks for getting back to me. Ended up popping into screwfix to buy a micrometer and it is as near as damn it. |
Sat Apr 20 2024 5:34pm |
