Home > In Car Electronics > L320 2011 stereo/ dvd/ Bluetooth issue |
Alan1981 Member Since: 19 Nov 2023 Location: Lincolnshire Posts: 8 |
Hi guys I have an issue with my infotainment system, basically firstly when you unlock the car it takes longer to boot up( ie the land rover symbol takes longer to load up in the screen)
Fri Apr 19 2024 1:41pm |
You could be right with blue tooth as every now an again it won't connect to my phone, is the Bluetooth module in the boot behind the drivers side panel? |
Fri Apr 19 2024 2:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4816 |
I believe so |
Fri Apr 19 2024 2:24pm |
I got a friend breaking one, maybe if he is selling the modules cheap I might just buy them off him but the Bluetooth one is definitely a target due to connectivity issues in the past. |
Fri Apr 19 2024 2:34pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4874 |
I think you may find the Bluetooth module is a integrated part of the IAM unit on a facelift vehicle, not a separate unit in the boot.
Fri Apr 19 2024 10:41pm |
2011 should be older system. But it is a bit close to the 2012 changer over. |
Sat Apr 20 2024 9:11am |
Mines the denso unit,which I belive is the older one, think new ones are bosch |
Sat Apr 20 2024 5:36pm |
Do I need to code them in btw? |
Sun Jun 02 2024 3:27pm |
no
Sun Jun 02 2024 5:39pm |
