Home > Technical > Handbrake question after body removal.
savi18
New Zealand
Hi Team, 12 months ago had new engine fitted to my 2009 2.7 v6 RRS, when they remove the complete body where do they disconnect the handbrake cable from do they leave the module in place and disconnect from the wheel side and hand brake switch, I’m was going to adjust the rear hand brakes shoes but if they removed the rear cables from wheels then they would most probably set the adjustment up. Cheers
Post #641217 Tue Apr 16 2024 10:14pm
peterjj
Australia
There is no 'cable' from the body to remove as it is triggered electrically. There is the emergency release cable that is removed from the body with a quick twist but that is not involved in any adjustment of the handbrake. ie removing the body will not affect the adjustment of the handbrake.
Smile Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #641218 Tue Apr 16 2024 11:50pm
savi18
New Zealand
Thankyou.
Post #641219 Wed Apr 17 2024 12:28am
