Home > Technical > 2014 TDV8 Timing Chain - One Bank Gone!!!! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
They do fail now and again on the v6. I think they are similar engine designs |
Sun Mar 17 2024 10:27pm |
2 RRS Member Since: 04 Sep 2016 Location: Stafford/Telford Posts: 107 |
I have seen a couple of posts over the years on the fullfatrr forum (where I am a member as have both a L494 (SDV6) & L405 with the V8 ). I recently rebuilt my 4.4 after a spun big end bearing. I think you will possibly find the cams will require replacing as I have seen spun lobes as they are an interference fit.
Mon Mar 18 2024 11:13am |
Garrfield Member Since: 20 Dec 2023 Location: Wokingham Posts: 33 |
Wow!! Unfortunate for you but a well described operation and the pics are a great help. When you see the front end removed it is quite a shock at how much pipework is involved in these cars!!
Mon Mar 18 2024 1:46pm |
Yep, 2 thousand miles in and running perfectly - thank god!
Mon Mar 18 2024 2:17pm |
Thanks Mike, sometimes to much information is sooooo scary!!! It seems regardless of which way I go there is one hell of a lot of work just to get to the chains before even considering changing them.
Mon Mar 18 2024 11:49pm |
