Home > Faults & Fixes > 2014 Range Rover Sport stuck in extended suspension mode |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
by the desiccant filter do you mean the cons shaped brass bit on the compressor? If not then remove that, its actually the silencer, new ones have a small hole drilled through the bottom and are about a tenner.
Thu Mar 14 2024 5:13pm |
pescaglini Member Since: 14 Mar 2024 Location: West Midlands Posts: 2 |
Yes that's right. I removed it completely and run the system for a day but it's still returning back to extended mode as default so not sure that's the issue? |
Thu Mar 14 2024 5:17pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
The EAS exhaust valve isn't exhausting. 2012 SDV6 - it's missing a couple of cylinders
Fri Mar 15 2024 12:22am |
