Home > Faults & Fixes > Fault code P0234 |
Wilco Member Since: 20 Mar 2021 Location: Somewhere in Time Posts: 30 |
Just had same code come up and like you engine seems to be running fine.
Sat May 22 2021 5:07pm |
Sold car last year,,later on after that happened I had problem with throttle body sticking,you could try some throttle body cleaner on the flap inside to help it,mine in the end went into Lr & had new throttle body fitted under warranty. Andy.
Sat May 22 2021 5:44pm |
Thanks, I found the thread about it and your photo of throttle body clip. So just removed mine and flap was a bit sticky so freed it and just off to Halfords to get some cleaner to spray on.
Sat May 22 2021 5:50pm |
Make sure it’s throttle body cleaner,,you don’t want anything going in the inlet to f@@k it up. Andy.
Sat May 22 2021 5:52pm |
Scootrover Member Since: 27 Sep 2021 Location: Staffordshire Posts: 4 |
Hi all, I am hoping you can help or share your wisdom!
Mon Sep 27 2021 9:50pm |
Throttle body sticking,I had same problem & LR fitted new throttle body under warranty.You could pull the pipe off the throttle body & spray with throttle body cleaner as it will free it off but don’t know for how long.Put a screwdriver under the metal clip pictured & pull it up then pull pipe off.
Tue Sep 28 2021 5:46am |
Thanks for the update, the light came back on today during a very steady drive home 😩
Tue Sep 28 2021 5:17pm |
Andrei Member Since: 04 Feb 2024 Location: Constanta Posts: 3 |
How did you solved the issue . I have the same thing with the overboost and dpf not regenrating . I ve change the throttle body and the map sensor and the overboost came back ! Please help i just bought the car and i dont know what else to do ! |
Sun Feb 04 2024 6:43pm |
