Home > Maintenance & Modifications > Replacing leaky ACE hydraulic lines. |
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 58 |
I’m sure it’s possible. Fittings to valve block and roll bars may be the sticking point. |
Sun Oct 29 2023 9:43pm |
Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64 |
Thanks for the reply. That’s a good point. Do you know if it’s possible to access and remove the existing pipes going onto both the front and rear roll bar assemblies with the body still on? If not that’s an immediate big problem? |
Sun Oct 29 2023 10:47pm |
You can, yes. |
Tue Oct 31 2023 10:25pm |
PhilnDeb Member Since: 02 Mar 2023 Location: Swindon Posts: 16 |
Have a look at my thread " slight body lift to replace ace pipes"
Tue Oct 31 2023 11:45pm |
Thanks guys, your input is very gratefully received. I’ll have a look now. |
Wed Nov 01 2023 11:22pm |
JAMO1282 Member Since: 18 Jan 2024 Location: Cumbria Posts: 14 |
Hi there just wondering if you manged to solve this problem as I have the same issue and was thinking about taking the old lines into Pirtek and seeing if they can make them up? Many thanks 2011 RRS 3.0TDV6 |
Fri Jan 19 2024 8:58am |
