Home > Maintenance & Modifications > 3.0 TDV6/SDV6 oil cooler change |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 435 |
Been having a bit of oil come down the back of the valley onto the bell housing lately. Decided I’d replace the oil cooler and oil separator while doing an oil change and other maintenance.
Sun Sep 03 2023 4:38pm |
a_a_t Member Since: 03 Sep 2019 Location: Bucharest Posts: 4 |
Hi! Planning to do a similar job on my Sport as well (2012 SDV6) and I've got a few questions for you, if you don't mind, please.
Mon Feb 26 2024 10:01am |
Original is Mann+Hummel. The Nissens is doing just fine with about 10,000km on it. Other than the updated bit you can’t tell them apart. I’ve installed a few Nissens oil coolers and haven’t seen any functional issues with them.
Tue Feb 27 2024 3:21am |
Thanks a lot!
Wed Feb 28 2024 6:22am |
I’d say that, too, changing oil pumps on a 3.0 diesel is a PITA.
Wed Feb 28 2024 6:39pm |
I did it at 60K because of age... the car had almost 7 years at that point (first owner did only 50K km in about 6 years... so either the car was used on short trips or was used only occasionally).
Wed Feb 28 2024 7:07pm |
That makes sense then.
Thu Feb 29 2024 9:05am |
Good to know that (hopefully) the glow plug job on the 3.0 might be a little easier
Thu Feb 29 2024 9:34am |
