Home > Off Topic > Any Gardeners on here ? |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I'm a keen gardener I'd like to think (he says setting himself up for a fall!). My routine is morning watering as I'm old and an early bird (often between 5.30-6am). I do mine once a week and every other week is a feed (tomatorite) and a dedicated rose feed exclusively the roses. Don't water during the hot/sunny day. It evaporates so a waste of water, plus in the hot sun it will burn the plant. If we have a hot period it will get a top up mid week. Grass will sunburn and you'd have to use massive amounts of water to keep it green, ce la vie. So to answer the question, am watering to hydrate before the heat. Make sure you water at the base of the plant where it meets the earth line, watering the leaves has little benefit. If you miss the opportunity do it when the sun has gone down.
Fri May 26 2023 12:24pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
From the experts - https://www.rhs.org.uk/garden-jobs/watering
Fri May 26 2023 4:57pm |
