Home > In Car Electronics > Apple Play in a RRS 2010 ? |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
https://www.navtool.com/land-rover-range-r...rface.aspx Regards etc.,
Tue Dec 20 2022 8:55pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
Got annoyed with Aux lead just plugged into jack plug socket under flap in rear of cubby box, so spliced it into harness under centre console. Just used lead that came with kit and cut it to suit, Pins 10 and 11 on grey plug, not sure why but Blue wire matches Red on jack plug and Red matches White just the way the L/R plugs wired I guess but works fine. Tidy and out of the way.
Sat Jan 28 2023 10:08pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
Very neat job Col, you wouldn't know you had Navtool in that little area under the cubby box. |
Sun Jan 29 2023 5:21pm |
Hi Dave, I actually fitted the IDcore unit not they Navtool one, also fitted it in the space under where the climate control panel fits, shame really if the harnesses had been a bit longer would have just about been able to fit under passengers seat.
Sun Jan 29 2023 8:44pm |
