Home > Wheels & Tyres > Correct size questionable
Autobiography1969
Hello All,
I am currently running my winter set up and the size is the same as the
OEM set up being 275/40/20 on 9.5Jx20
I am looking to get a new set of 22" wheels,
as I made a mess of two of the ones I have,
but my question is this,
I have been running 285/35/22
but surely to keep the correct aspect ratio it should be 295/30/22
Is there a reason everyone runs 285/35/22?
and does that mean the speedo is always 4% out
30mph really being 28.8mpg
Can they be adjusted with the IID tool to correct the speedo??
if so I will possibly increase the side wall to 285/40/22 ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #629639 Thu Jan 05 2023 12:56am
I think you may find 285/30 x 20" is actually the closest to the 275/40 x 20", and no it will not make a blind bit of difference to the speedo reading that you will notice by changing the tyre size in the ccf files, however the 285/35 would proably make the actual speedo reading more accurate than the orginal 275/40 as I'm sure by law a speedo has to read fast by a certain percentage, or at least that used to be the case. If you are talking about winter tyres I would have though smaller dia. rims with higher profile tyres would be the better option, as 22" rims were never a factory option on the L320 in either case.
Post #629641 Thu Jan 05 2023 5:12am
Tyrefitter
When I had my L320 on 22’s I was running 285/35r22 & the actual Speed was slightly lower.
[/b] Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #629642 Thu Jan 05 2023 9:12am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
When I fitted my 22" wheels I had 285/35/22 and the speedo was under, I now have 285/40/22 and the ride is better by a long shot and the speedo is about perfect to my GPS.
Post #629645 Thu Jan 05 2023 10:08am
Autobiography1969
Great info guys, thank you all very much.. ===========================================
Post #629668 Thu Jan 05 2023 10:35pm
