Home > In Car Electronics > New Android auto 12.1 Tesla for RRS 05-09
Page 5 of 6 <123456>
mrluke
J50nmw wrote:
Thankyou most appreciated
Hey Guyzer ,
Interesting that you are also using the P4A website , I tried to find my unit on there but finding it hard with the translation barrier.
Post #607468 Mon Dec 14 2020 9:41am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Hey MrLuke,
Yeah, not useful that's it's in Russian, however, my wife is Ukrainian so with some bribes Whistle she helps me out occasionally.
But to be fair there is so much information there it's somewhat confusing.... 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #607469 Mon Dec 14 2020 10:00am
savi18
New Zealand
New site to buy radio
https://phoenixautomotiveins.com/products/...t_campaign
Check out this site and see what you think. Guyzer
Post #608093 Sun Jan 03 2021 5:48am
brianx2t
Guyzer73 wrote:
3. Internal mic not working cannot make or receive telephone calls. This was a hardware problem, the ribbon cable was loose. I've reattached it and all is good again.
Hi, any chance that you could point out where the loose cable is reattached? I also have the loose cable (well, completely fallen off) but I can't for the life of me find out where to plug it back in. Big Cry
Post #612231 Sat Apr 03 2021 10:35am
Thewilbury
Ireland
to anyone who has purchased this unit.........
is it worth it?
Post #616321 Mon Aug 02 2021 11:53pm
J4XHY
United Kingdom 2007 Range Rover Sport TDV6 HST Java Black
Thanks for the info guys.. Few Q's.
- My unit seems to loose the correct time. I've trued with and without GPS sync activated. If I click reboot the time updates.
- Can't seem to find a option to turn off the camera lines?
- Is it possible to change the distance to miles instead of km etc I found a screen but cannot change anything
Thanks
Post #618067 Tue Oct 12 2021 8:58pm
benc
Australia 2007 Range Rover Sport TDV6 S Java Black
Hi - I purchased one of these for my 2007 Range Rover Sport. I have the model without the upper navigation screen it has a plastic tray instead that is built into the dash. Has anyone had any luck cutting out the tray and installing?>
Post #618477 Thu Oct 28 2021 3:57am
chris101970
United States 2009 Range Rover Sport 4.4 V8 HSE Zermatt Silver
[quote="Guyzer73"]Hi,
Yes they work perfectly with the Logic 7 system. They say you can't fade front to back but with the DSP it seems to work, so not really sure what's going on there...
However, currently you can get the updated Android 10 versions which should offer better functionality such as automatic night and day mode which is something I miss on my Android 8.1 system and the manufacturer is saying they won't provide Android 10 update as not compatible, which in my opinion is BS....
Guy[/quote
Guy I realize this is an old thread, but I am getting no sound with this installed and Logic 7 system.
My unit differs very slightly having the rear connectors all in a row instead of two rows, but otherwise it looks the same. The harnesses supplied seem a little different also. My main power wiring harness has many more wires in it than what your shows but does not have the second squarish connector. MOST box and CANBUS installed. Also, I have a small red wire from the harness where all the other RCA and analog connectors are that is labeled AMP COM that has no where to go.
Im at a loss - I feel like i've tried all the settings for sound and they are as they should be. It looks to be running Android 12 and is otherwise operating well.
Post #631908 Sun Mar 26 2023 4:11pm
J4XHY
Hi, have u tried disconnecting the battery. I had no sound when I first installed and this worked for me. Presume the amp had faulted. Cheers
Post #631911 Sun Mar 26 2023 5:35pm
chris101970
I have not but will try that and report back
thx
Post #631912 Sun Mar 26 2023 5:39pm
chris101970
That totally worked!! Cant thank you enough.
Now on to the rest of this install......
Post #631913 Sun Mar 26 2023 7:22pm
J4XHY
Excellent..glad it worked for you 😎
Post #631930 Tue Mar 28 2023 2:40am
lemon
Hey everyone, have read through this whole thread with interest as I am looking to get one for my 2007 RRS 4.2 SC...
Where is the best outlet for them? I see loads on Aliexpress and varying prices, presumably all the ones that say they are 8GB RAM with 256GB ROM and running Android 12 are all the same? Also as I have the logic 7 speakers I presume I also need the fibre decoder box seperate, and other than that it'll all be plug and play?
Saw some talk about cutting part of the dash?
Thanks a lot for all the info you have posted on here previously...and I am looking forward to enjoying my first RRS Smile
Post #636203 Thu Sep 28 2023 12:59am
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I have bought mine here, 3 years ago.
https://unique-ad.co.uk/
Very happy with the unit and satisfied with their (aftermarket) service. Reliable company, selling good products.
Post #636204 Thu Sep 28 2023 6:07am
lemon
Thank you for your response though they don't seem to do them there now.
Post #636206 Thu Sep 28 2023 8:52am
