Home > Tips & Tricks > Memory function |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Just noticed today that with the diffrent keyfobs when activating the lazy entry it also will change the display mode from miles to km depending what was last set when you used the car last. My key was used with km/h and the SWMBO last used the car in the UK and was using mph. When she took us all out for a drive today the dash / sat nav reverted back to mph and miles per gallon. She then locked the car and I opened it with my key and it came back up in km/h and l/100km.
Wed Nov 28 2007 8:48pm |
Didn't know that either - good spot!
Thu Nov 29 2007 12:14pm |
Socketuser Member Since: 23 Oct 2018 Location: Preston Posts: 7 |
How do you turn off lazy entry.
Mon Sep 16 2019 6:08am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
You can't because it doesn't have it on a 62 plate car, it went out in 2009 with the pre facelift cars. It's now called Entry & Exit mode controlled by rotary switch on steering column just turn to off position.
Mon Sep 16 2019 6:18am |
Preston-rr Member Since: 10 Sep 2010 Location: Preston Posts: 239 |
what is entry and exit mode? how do I set it, what does it do? Novice here has no idea? 2014 RRS HSE, SVR body kit fitted.
Thu Oct 08 2020 12:18pm |
Small rotary "Knob" on steering column below Wiper/Washer stalk on a RRS2 I believe.
Thu Oct 08 2020 11:31pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Its on the left hand side of the steering column so that makes it below the indicator stalks doesn't it?
Fri Oct 09 2020 4:53am |
I think Preston-rr now has a 2014 RRS2 so opposite side of column.
Fri Oct 09 2020 5:40am |
Ah! OK. Robin
Fri Oct 09 2020 6:38am |
Thanks will try it out. 2014 RRS HSE, SVR body kit fitted.
Fri Oct 09 2020 7:08am |
Yup - 2 positions - Auto and Man Robin
Fri Oct 09 2020 7:45am |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Definitely fitted to the my 2012 (13MY) L320 too. There is no replacement for displacement - W O Bentley
Fri Oct 09 2020 7:55am |
Ianc51 Member Since: 17 Oct 2015 Location: Portsmouth Posts: 3 |
Does the 2014 RRS have entry and exit mode? I leave the steering column switch in auto, the wheel moves up on exit but the seat does not move. Any ideas please.
Wed May 19 2021 11:11am |
Just a couple of guesses to try but (1) is the seat already all the way back (i.e. you're very tall)? If so it's got nowhere to go and (2) is your seat position stored in the memory as (I guess) this is what it uses to establish positions. Probably way off the mark, but maybe... Robin
Wed May 19 2021 5:30pm |
