Home > Wheels & Tyres > Goodyear Wrangler Duratrac 255/65/19 or 255/55/19 |
robtheranter Member Since: 05 Sep 2020 Location: Scottish Borders Posts: 10 |
New to this so be gentle.
Sat Sep 05 2020 10:50am |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 |
I have driven 255 55 19’s Duratracs on and off road with no problems or adjustments at all and was just fine.. |
Sat Sep 05 2020 7:04pm |
The cars a RRS it's only the 19in rims that are from a disco 3 |
Sat Sep 05 2020 9:53pm |
I think the 255/55/19, are the standard winter tyre size and come in at 30in total diameter and the 255/65/19 are 2in bigger at 32in hence the 2in lift.
Sun Sep 06 2020 8:52am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8870 |
255/55/19 was never a standard RRS size at all. Only the G4s had that size. Standard size is 255/50/19. 255/55/19 was the size on the Disco.
Sun Sep 06 2020 9:08am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
I'm running 275/55R20s which are minimally smaller than the 255/65/19s.
Sun Sep 06 2020 11:54am |
Glad to hear I'm on the right track, I didn't think I would have problem with the back I've been so fixated on the front, i'll get the tape out and double check . With the 50mm lift engaged everything seems to be ok with the 32in wheels but its great to hear from someone with first hand experience. |
Sun Sep 06 2020 12:29pm |
If I was wanting to build an RRS for predominantly off road use, I'd go with 18 inch rims and BF Goodrich KO2 in 265/60/18.
Sun Sep 06 2020 2:11pm |
Tried and failed to go down the 18in rim route.
Sun Sep 06 2020 4:16pm |
Another option would be to stick with 20s and use the 275/55R20s I have. They are a number of options available including the KO2.
Mon Sep 07 2020 7:51am |
Thanks for that,
Mon Sep 07 2020 3:00pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
There's some on the D3 site right now for less than 1K 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Fri Sep 11 2020 2:24pm |
Tried the car with the 50mm lift for a couple of weeks with the original 20" wheels and 275/40s just to see if it was ok and I can honestly say it feels awful.
Thu Sep 17 2020 5:53pm |
Good combination of 255/55/19. Have run the same set of Duratracs for the last 35K miles. All down to around 5mm now with regular rotations front to back and i have noticed they are starting to wear alot faster now so i will change them all before Winter arrives. In that time i have had one puncture.
Thu Sep 17 2020 9:47pm |
