Home > Tips & Tricks > Intercooler Hoses |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Hi i've just ordered the set of 3 hoses from advanced factors, hoping this will sort out the lack of power below 2000 rpm.
Thu Jul 30 2020 8:38am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
The workshop manual is available here: http://www.mediafire.com/file/yunzrqm47py4...6.pdf/file
Thu Jul 30 2020 9:40am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
If we are talking about the same things, my Indy found a split in one of the two top intercooler hoses on my TDV8 2008 and it was a 5 minute job. They are the two big ones on top of the engine. I think he just unclipped the top engine cover and then its a couple of jubilee clips on each hose.
Thu Jul 30 2020 11:55am |
Cheers for the info the V8 is a different set up to the V6, thanks for the manual still trawling through it. |
Thu Jul 30 2020 2:40pm |
Changed the long one no obvious splits but a bit oily around the bottom, i think i may have been loose as only a few drips of oil come out, tested for about half hour i now can accelerate now , got a long run to london monday so will see if fully cured then. |
Sat Aug 01 2020 8:52am |
