Home > In Car Electronics > Rear demister / defroster
Page 3 of 3 <123
JD1579
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
[size=18][size=9][size=18]Hi Guys, i know this post hasn’t seen any activity recently but it’s something i’m having issues with. I’ve managed to get it all apart and for the life of me can’t get the connector to come apart!! I can see how you describe what to do with a screwdriver but i’m not sure what part you mean? PLEASE HELP
Post #591246 Sat Nov 30 2019 2:30pm
is there not a little clip on the side that you need to pull up with a tiny screwdriver ?
if you already did this, it's possible the terminals have rusted or burnt together
Post #591260 Sat Nov 30 2019 6:37pm
JD1579
Thanks for the reply. I’ve managed to get it off with some force. Slight damage to the connector housing but after giving it a good spray and clean inside (even though i was sure it was too gone to work looking at the condition of it) it has WORKED! All lines seems to be working and de-misting as they should.
Post #591263 Sat Nov 30 2019 6:50pm
mlambton
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Rear heated window connector replacement
I have the common heated rear window connector corrosion problem so took the plug behind the spoiler apart. Its partly disintegrated so would like to replace the 2 pole connector. My question is what rating should the connector be?
There seems to be very few over 20A out there on the "automotive connector" sites. My handbook tells me its a 30A fuse to the rear heated window...so does this mean i need a 30A connector?
Post #616398 Thu Aug 05 2021 5:20pm
Was gonna say 30A
Post #616402 Thu Aug 05 2021 7:26pm
Page 3 of 3 <123
