Home > Off Topic - Other Cars > Muddys Mini Countryman Cooper S All4 PHEV |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Who new owning an RRS would lead to this: Petrolheads turned into Sparkies
Wed Nov 27 2019 6:19pm |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
Agree Jim
Wed Nov 27 2019 7:23pm |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 376 |
Hi Muddy,
Wed Nov 27 2019 7:46pm |
Hi Tim - I did keep logs
Wed Nov 27 2019 8:37pm |
If still in Channel Islands prob 1 car all electric but when I was there lot of travel off island with bigger mileage so prob still a diesel for longer journeys. Looking at details other Tim posted:
So not really an AWD at all for wintry conditions. It will be interesting to see if Phev versions of Mini hold their residual value any better than the petrol or diesel models which are pretty poor. Another issue which is not widely known is that especially for fast charging units to be fitted at home can require expensive upgrading of home electrics. I know this would effect myself as put an office in the garden and if I had upgraded the electrics then would of been around 2K Now driving a rather smart looking Van |
Thu Nov 28 2019 6:11pm |
Lespes - reason I bought nearly new 2019 is l saved £13.5k vs new
Thu Nov 28 2019 9:22pm |
Charger sockets at home can be a pain - I was advised even for the mini to have a heavy duty socket and spur put in to cope with the extra load. My friendly electrician put in much heavier duty spur than I need incase I get a car that needs a proper home wall box charger. Even wall boxes are limiter to what output they can handle and even on one of those units charging a BEV car takes 10-12 hours. You cannot use the Public 50kW and bigger rapid chargers with the Mini As you will destroy the battery and they have charge limiting software that restricts the amount of charge they can take. I have been told that if I bought an IPace or Tesla then to get >50kW /hr charging you would need 3phase at home and that is very costly to install and has its own standing charge on SSE! My father has just had his 3 phase system disabled in his workshop But everything is there for reconnection if necessary. Also rapid chargers only charge to 80% battery then take for ever to charge the last 20% and I have been warned that using high speed chargers a lot reduces the battery life......... you cannot win!
Thu Nov 28 2019 9:25pm |
I take your point on All4 Lespes - the Mitsy had motors front and rear and electric diff lock. The Mini is rear wheel electric and front petrol so to use 4wd you need everything running. Today I had to reverse up steep wet drive to park and felt tyres slipping as I had locked in EV mode. It recovered quickly using traction control presumably but I will have to think in poor weather about using EV mode only Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Nov 28 2019 9:29pm |
In snow and very wet weather best to leave it in Auto e-Drive mode then both power sources will cut in together when needed, there is no Haldex/Torsen or anything other than a data cable connecting the front and rear axles in the Mini PHEVs system unlike the other All4 Minis that have them.
Fri Nov 29 2019 7:20am |
Cheers Tim
Fri Nov 29 2019 9:40am |
Goodyears are a better tyre Andy.
Fri Nov 29 2019 10:34am |
These Paul,,obviously not that price they work out cheaper with your forum discount & Maccy D's coffee
Fri Nov 29 2019 10:37am |
Money saving tip here Paul....... if you still have a rubber boot mat from your DiscoSport it’s worth trying it in the Mini........ I still had the mat from my last Evoque, fitted perfectly in the Mini’s boot apart from having two cut outs where the Evoque had two cargo tie down rings built into the boot floor, but it works well and lifts easily to access the charge cable stowage under the boot floor of the Mini. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Nov 30 2019 1:44pm |
Cheers Tim - I'm all for saving money
Sat Nov 30 2019 6:46pm |
