Home > Off Roading & Green Laning > Rock sliders |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
It does stick out, though as you said, tight in places. Pic is from where it's closest and despite image pole was vertical. Gap was 1/2 cm I would say
Fri Nov 01 2019 12:54pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I can think of a tree-stump on Salisbury Plain that I need those for. It's got me twice! |
Fri Nov 01 2019 2:16pm |
I'm thinking some of the narrow lanes around Brechfa, in particular so-called Panel Beater |
Fri Nov 01 2019 2:29pm |
Do the original plastic trims stay in place along the sill? Would like to see some more pics please with doors open please 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐ |
Fri Nov 01 2019 8:02pm |
Just finished doing the other side, took about an hour all in all but that's because a) I again had problems getting out the rear two Phillips on the plastic valence b) I'm somewhat space limited and c) on my own. To be fair I wasn't in a rush either. I'll do pics another time as its still peeing down here.
Fri Nov 01 2019 8:37pm |
Sun came out for a few minutes this morning!
Sat Nov 02 2019 11:14am |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 |
Wish mine had not come with the steps on as i really like the look of these, also Pufftmw if your winch mount is an LR product then it is the G4 winch cradle. |
Sat Nov 02 2019 2:12pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Looking at the various pictures, I'd say these are solely tree sliders intended to stop a tree or rock from hitting the door. They're not rock sliders (they'd have a smooth underside if they were) and they don't look like they would take too much vertical load without risk of deflecting and preventing the door opening. 2012 SDV6 - it's missing a couple of cylinders
Sat Nov 02 2019 3:51pm |
You're probably right. I have already given the feedback about dual rock/tree sliders, so they might make a change maybe. They are pretty sturdy though, so I imagine would take quite a bit of vertical punishment before coming out of place. This is the same design they use for other tree sliders, so I guess they know what they're doing.
Sat Nov 02 2019 7:32pm |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
Iยดm agree , this design is closer to a side step ( very sturdy ) than a tree/rock slider , the load will be transmitted to the sill not to the frame (aka chassis ) and will bend . You should use the underside bolts and the two body to chassis mounts per side TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Sat Nov 02 2019 9:38pm |
And this is why I would like this design, as it covers all bases. The AJS one looks more sidestep design but stronger, so wont be for me 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐ |
Sun Nov 03 2019 8:36am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Happened across this site when looking for sliders, and underbody protection:
Sun Nov 03 2019 10:49am |
Come on!! I hope this video will give motivation in the fab process TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Mon Dec 30 2019 7:52pm |
boostedt0y Member Since: 07 Aug 2020 Location: California Posts: 10 |
Voyager sliders on my l320
Sat Dec 19 2020 8:46am |
