Home > Off Roading & Green Laning > 2019-05-12 - Salisbury Plain |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8867 |
You're not having much luck with tyres on your trips out, are you? 2012 SDV6 - it's missing a couple of cylinders
Sun May 12 2019 11:39pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I think I'm cursed. Mind you, I got the wheel off pretty quickly - practice!
Mon May 13 2019 7:57am |
Does your RRS have the bigger brakes fitted? Being a relatively early one, I wonder if you could fit the 18inch rims and go for something a bit tougher such BFG KO2. Or even the 17 inch that the very first were available with I believe. 2012 SDV6 - it's missing a couple of cylinders
Mon May 13 2019 11:18am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
No Report on the Surrey Hills trip Hugh? |
Mon May 13 2019 12:06pm |
It's here, James.
Mon May 13 2019 1:57pm |
Must use eyes...
Mon May 13 2019 2:02pm |
It was all fun, though that part did raise my pulse-rate quite a bit. There are quite a few barriers with a 7' gap to allow vehicles (but not tippers, etc.,) through. That gives a couple of inches on each side, right? Yes, but they have also installed a series of staggered concrete blocks: these have the effect of tipping the car and making it very, very, very close to the upright of the gate |
Mon May 13 2019 2:28pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1250 |
Hey that looks great fun. Your using your car more than most would.
Mon May 13 2019 4:16pm |
