Home > General > ignition live in bonnet ???
saty
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all,
I need an ignition live in the bonnet area for my LED DRL's, as having some issues using the non ignition live.
Was told to use FUSE1 in the fuse box, but if I was looking correctly at the fuse box this was closest to the windscreen and I could not get to the cables underneath to tap into it Confused
Can anyone help with either how do I get to this one or where I can get another easily ?
Post #385096 Mon Jun 10 2013 12:18pm
Sorry Saty,
I've just had a look under my bonnet to see where the auto electrical guys wired mine into, but they've done such a good job I cannot find the feed! RRS gone
Post #385102 Mon Jun 10 2013 1:12pm
flydive
In mine I took the feed from one of the empty relay sockets, you can just plug in with a normal spade connector.
Check which one is under ignition and add an inline fuse.
I did this way to bring power behind the grill for DLRs and horn. '08 RRS TDV8
Post #385103 Mon Jun 10 2013 1:44pm
saty
awd man wrote:
Sorry Saty,
Laughing thanks anyway
I did this way to bring power behind the grill for DLRs and horn.!
Ahh this sounds like a plan, could you possibly take a pic of which one you put a spade into ..? .. already got the in-line fuse and cable wired and ready, just need the ignition power.
Post #385104 Mon Jun 10 2013 2:16pm
baxc
pm sent
Post #385106 Mon Jun 10 2013 2:40pm
flydive
Here is the one I used.
Please note that mine is a LHD so might be slightly different, also depending on the equipment.
 '08 RRS TDV8
Post #385109 Mon Jun 10 2013 3:07pm
saty
baxc wrote:
pm sent
Thanks buddy & PM replied.
flydive thanks mate that is perfect, now I know exactly what to do, pictures speak a 1000 words.. Cheers Thumbs Up Bow down
Post #385111 Mon Jun 10 2013 3:28pm
saty
Found the plug and all working.. Thanks for the assistance everyone Wink
Post #385134 Mon Jun 10 2013 8:52pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
The Old Threads Are The Best....
Just been reading this as im looking to wire up an original set of Range Rover DRL's that I managed to get my hands on last year. I already have some headlight led's wired up, but these are as side lights.
Couple of questions as im a complete novice at this:
1/. Is it a 12v fuse that is required for the in-line fuse?
2/. Could the power to the sidelights (orange/black wire) also be wired to this constant power source so that the sidelights (or in my case Headlight LED's) are permanently on?
One other question, my DRL's have an option of "DRL" or "DRL and Position Light." Anyone know the difference?
Thanks! 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #459550 Fri Apr 17 2015 7:14pm
Lost for Words
Yes. Always best to use a relay too.
Yes again. Make sure you create good waterproof connections if your tapping into the vehicles wiring. Wink
I would suggest you use a relay to shut the DRLs off with the headlights too. Thumbs Up
Can you post a picture or a link to the relevant lights? Is there an additional feed built into them? Question Visiting from DISCO3.CO.UK
Post #459610 Sat Apr 18 2015 8:10am
Tim in Scotland
Isn't the "positon light" the additional light that is part of the Adaptive Headlights that comes on at less than 30MPH when turning and illuminates the kerb/ road edge? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459612 Sat Apr 18 2015 8:25am
Lost for Words
That's the cornering/static bending lamp. Thumbs Up Visiting from DISCO3.CO.UK
Post #459616 Sat Apr 18 2015 8:44am
Tim in Scotland
Then the other thing it could be is the lamp fitted behind the orange front and rear side refelctor plates that are part of the lamp units for the USA spec cars but not fitted in European Market cars as far as I know. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459618 Sat Apr 18 2015 8:53am
Lost for Words
I assume it means just a standard sidelight but what I'm wondering is, is it a separate light, or does it dim, or is it related to its functioning in relation to the vehicle sidelights? Visiting from DISCO3.CO.UK
Post #459619 Sat Apr 18 2015 9:00am
darrenmcneill
[quote="Lost for Words"]
Very late reply but here's the pic. This has been in the garage for 8 months so thought I'd best pull my finger out.
One feed is "DRL & position light," one feed is DRL ONLY.
Any ideas?
Post #469915 Sun Aug 09 2015 12:11pm
