Home > Faults & Fixes > Front and rear heated screens take ages to work |
Front - normal Rear - not normal. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Jan 17 2012 2:03pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8873 |
Front screen takes 6 minutes? Not normal in my experience. The front screen has been clearing in less than 2 minutes with -4degC outside. Are you directing air on it too? With the FBH, the air in mine is warm in about a minute and this really helps the front screen defrost. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 17 2012 5:05pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
Agree 6 mins is not normal for me either. Closer to the 1-2 mins on the front and a little longer on the rear.
Wed Jan 18 2012 10:58am |
Stuart's the man Member Since: 02 Jan 2012 Location: Glasgow Posts: 35 |
front screen 2 minutes tops to clear |
Sat Jan 28 2012 1:45pm |
DrNick_B Member Since: 03 Sep 2011 Location: Warwickshire Posts: 3 |
I reckon your theory is spot on!!!! If I start my 58 plate RRS on a cold day and immediately switch on the heated front screen, it doesn't work!! If I wait until a little puff of white smoke from under the front N/S tells me that the diesel engine heater has successfully started up and then switch on the heated front screen, it typically clears the screen in about a minute! I've had the debate with JLR about battery and alternator performance on both this RRS and my previous one, but they don't go with out theory!!! lol |
Thu Jan 24 2013 10:54pm |
