Home > In Car Electronics > Sat nav problem |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 |
After some help.
Wed Jan 09 2013 10:08pm |
LOL
Wed Jan 09 2013 11:28pm |
It worked! but is still the same as the 2006 disc. Can't see what I'm gaining by updating the disc. I only done it because I wanted the version 3 display
Thu Jan 10 2013 10:29pm |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
I had the same problem when i bought a genuine disc to update mine to 2012.... Defaulted to europe map Why?.. Because i can....
Thu Jan 10 2013 10:52pm |
The disc only has the maps not the firmware that gives you the display Mike 2014 Facelift Discovery |
Thu Jan 10 2013 11:22pm |
How do I update that? Is it a job for bodsey? |
Fri Jan 11 2013 12:02am |
You might be able to do a slight upgrade but you wouldnt be able to go too far...i cant recall the MY range you can go to sorry Mike
Fri Jan 11 2013 12:28am |
It changed at 2010 model change I think.
Fri Jan 11 2013 1:33am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
As far as I am aware you cannot upgrade to the latest "look and feel" SatNav as its a completely different system from a different manufacturer.
Fri Jan 11 2013 9:09am |
You cant go to the new 12MY on system or the HDD navigation system thats on the 10 or 11 on or actually from 10/11 to 12/13 Mike 2014 Facelift Discovery |
Fri Jan 11 2013 5:58pm |
Glad I read this thread - gave me the courage to try my 'bargain' disc which (once I had changed the country to UK from the default Belgium) seems to work perfectly well so far. 2008 MY Java Black TDV8 HSE
Sun Jan 13 2013 9:12pm |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 |
Just been reading this pst as have similar fault. I had to change rom Belgium to UK but ave to do ths every time the sat av sarts up. Did you experience this problem? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
Wed Jan 16 2013 1:58am |
No; I only had to change from default Belgium to UK once at the 'destination' screen as described by Bodsy above and my £10 fleabay bargain disc appears working just fine. 2008 MY Java Black TDV8 HSE |
Wed Jan 16 2013 12:07pm |
Ok thanks for clarifying TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Wed Jan 16 2013 12:32pm |
