Home > In Car Electronics > Rear demister / defroster |
Same here and front screen heating not working either. That post about getting to the corroded connection under the rear spoiler was something like: open the rear hatch and remove three bolts and then open the glass section only and remove three Torx bolts being careful to avoid scratching the edge of the roof. I can't find post as something has changed on search facility and can't seem to use Boolean technique??? Good luck. I've checked fuses and all OK. Charging battery with trusty CTEK in case that helps. Too chuffing cold to spend more time on it today! 2008 MY Java Black TDV8 HSE
Sat Dec 01 2012 4:33pm |
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 |
Thanks for that info. I'm going to try and dismantle the upper tailgate area either tomorrow or Monday. I've got the use of my dads garage so I'm not outside in the cold!
Sat Dec 01 2012 6:48pm |
Good luck! Just had a quick check and there are 3 bolts visible with main tailgate open and 2 biggish torx bolts visible with the glass section open. After charging the battery with CTEK smart charger yesterday and pulling and checking all the fuses my heated front screen mysteriously worked this morning: all the frost started melting and sliding down the screen after about 30 seconds or so . No such luck with the rear screen heater; can hear a relay click when switched on but no heat so guessing there is a break in the live feed somewhere. 2008 MY Java Black TDV8 HSE
Sun Dec 02 2012 1:38pm |
Thanks for checking for me. I haven't had chance to do anything with it today. We spent the day out in it and from when I got in this morning, the front heated screen was a god send. Mine had been stood for 3 days but after about a minute and half it cleared and during the warm up I could see the steam coming from it. Also the fuel burning heater was working as I got a bit of smoke/steam from under the car too.
Sun Dec 02 2012 4:58pm |
NDR311 Member Since: 01 Dec 2012 Location: Aberdeenshire Posts: 1 |
My heated rear screen does not work and the upper window doesn't release. Fuses ok. Tailgate opens and wiper/washer works. Anyone experieced similar? Local (non-franchised garage thought "relay" although they've not looked at it. Warranty out by 1 month and I'm not too keen on the £110/hr labour charge at the local dealer to go troubleshooting.... |
Mon Dec 03 2012 5:50pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
NDR, your tailgate release switch is probably corroded. Common problem. Remove the rubber cover and have a look at the switch underneath. These are known to create a short and drain the battery over night.
Mon Dec 03 2012 7:49pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Kav, the rear quarterlights don't demist. Those lines are aerials, not demisting wires... 2012 SDV6 - it's missing a couple of cylinders
Tue Dec 04 2012 11:08am |
Thanks mate - I'm a sausage
Tue Dec 04 2012 5:15pm |
In Bobby's gallery - Removal of rear spoiler.
Thu Dec 06 2012 7:06pm |
Nice one Paddi. There is also a video on YouTube (link is in definitive how to thread)...
Thu Dec 06 2012 7:49pm |
Ok, mine is all sorted
Mon Dec 10 2012 11:18am |
Thanks for that kav
Mon Dec 10 2012 1:02pm |
Kav - thanks for posting that. Fingers crossed mine is the same problem. Was going to give it a go over the weekend but 'quick' job of replacing my number plates turned out to be a three hour hassle and ran out of time 2008 MY Java Black TDV8 HSE
Mon Dec 10 2012 1:23pm |
Every time I tell the missus it'll be a quick job, she goes and puts on the 'sex and the city' omnibus because it never takes me less than 5 hours
Mon Dec 10 2012 2:37pm |
