Home > Technical > Help with a Fault code please
P1623
Land Rover website say it's a BMW peddle sensor fault but I'm not 100% mine has any BMW in it! RRS gone
Post #323703 Fri Dec 02 2011 5:08pm
airwolf222helicopters
Trouble Code Chart
DTC Fault Description
P0101 Mass Air Flow Sensor Signal Error Fault
P0102 Mass Air Flow Sensor Low out of Range Fault
P0103 Mass Air Flow Sensor High out of Range Fault
P0111 Air Temperature Signal Error Fault
P0112 Air Temperature Low out of Range Fault
P0113 Air Temperature High out of Range Fault
P0116 Engine Coolant Temperature Sensor Falling Temp Fault
P0117 Engine Coolant Temperature Sensor Low out of Range Fault
P0118 Engine Coolant Temperature Sensor High out of Range Fault
P0121 Throttle Position Sensor Output Signal Error Fault
P0122 Throttle Position Sensor Low out of Range Fault
P0123 Throttle Position Sensor High out of Range Fault
P0125 Engine Coolant Temp Sensor Warm Up Fault
P0130 Oxygen Sensor Cycle Fault* *codes* A U
P0131 Oxygen Sensor Low Voltage* *codes* A U
P0132 Oxygen Sensor High Voltage* *codes* A U
P0133 Oxygen Sensor Slow response* *codes* A U
P0136 Oxygen Sensor Cycle Fault* *codes* A D
P0137 Oxygen Sensor Low Voltage* *codes* A D
P0138 Oxygen Sensor High Voltage* *codes* A D
P0139 Oxygen Sensor Slow response* *codes* A D
P0150 Oxygen Sensor Cycle Fault* *codes* B U
P0151 Oxygen Sensor Low Voltage* *codes* B U
P0152 Oxygen Sensor High Voltage* *codes* B U
P0153 Oxygen Sensor Slow response* *codes* B U
P0156 Oxygen Sensor Cycle Fault* *codes* B D
P0157 Oxygen Sensor Low Voltage* *codes* B D
P0158 Oxygen Sensor High Voltage* *codes* B D
P0159 Oxygen Sensor Slow response* *codes* B D
P0171 Oxygen Sensor System Too Lean Fault Bank A
P0172 Oxygen Sensor System Too Rich Fault Bank A
P0174 Oxygen Sensor System Too Lean Fault Bank B
P0175 Oxygen Sensor System Too Rich Fault Bank B
P0181 Fuel Temperature Sensor Signal Error Fault
P0182 Fuel Temperature Sensor Low out of Range Fault
P0183 Fuel Temperature Sensor High out of Range Fault
P0201 Injector 1 Circuit Fault
P0202 Injector 2 Circuit Fault
P0203 Injector 3 Circuit Fault
P0204 Injector 4 Circuit Fault
P0205 Injector 5 Circuit Fault
P0206 Injector 6 Circuit Fault
P0207 Injector 7 Circuit Fault
P0208 Injector 8 Circuit Fault
P0300 Misfire on Multiple Cylinder
P0301 Misfire on Cylinder 1
P0302 Misfire on Cylinder 2
P0303 Misfire on Cylinder 3
P0304 Misfire on Cylinder 4
P0305 Misfire on Cylinder 5
P0306 Misfire on Cylinder 6
P0307 Misfire on Cylinder 7
P0308 Misfire on Cylinder 8
P0326 Continuous Knock Fault Fault Bank A
P0327 Background Noise Low Fault Bank A
P0328 Background Noise High Fault Bank A
P0331 Continuous Knock Fault Fault Bank B
P0332 Background Noise Low Fault Bank B
P0333 Background Noise High Fault Bank B
P0335 Crankshaft Position Sensor Signal Error Fault
P0336 Crankshaft Position Sensor Out of Range Fault
P0340 Camshaft Position Sensor Signal Error Fault
P0420 Catalyst Efficiency Low Fault Bank A
P0430 Catalyst Efficiency Low Fault Bank B
P0441 Evap. Purge Valve Incorrect Flow Fault
P0442 Evap System Small Leak Detected Fault
P0443 Evap. Purge Valve Open or Short Circuit Fault
P0451 Fuel Tank Pressure Sensor Signal Error Fault
P0452 Fuel Tank Pressure Sensor Low Out of Range Fault
P0453 Fuel Tank Pressure Sensor High Out of Range Fault
P0461 Fuel Tank Level Measurement Not Valid Fault
P0500 Vehicle Speed Sensor Signal Error Fault
P0506 Idle Speed Control Engine Speed Low Fault
P0507 Idle Speed Control Engine Speed High Fault
P0560 Battery Voltage Below minimum Fault
P0562 Measurement Circuit OK Battery Voltage Low Fault
P0563 Battery Voltage Above Maximum Fault
P0605 ECM Self Test Fault
P1130 Oxygen Sensor Fuel Trim at Limit *codes* A U
P1131 Oxygen Sensor Lean *codes* A U
P1132 Oxygen Sensor Rich *codes* A U
P1137 Oxygen Sensor Lean *codes* A D
P1138 Oxygen Sensor Rich *codes* A D
P1150 Oxygen Sensor Fuel Trim at Limit *codes* B U
P1151 Oxygen Sensor Lean *codes* B U
P1152 Oxygen Sensor Rich *codes* B U
P1157 Oxygen Sensor Lean *codes* B D
P1158 Oxygen Sensor Rich *codes* B D
P1171 Oxygen Sensor System too Lean Fault Banks A & B
P1172 Oxygen Sensor System too Rich Fault Banks A & B
P1176 Maximum Positive FMFR Correction Fault
P1177 Maximum Negative FMFR Correction Fault
P1178 Maximum Positive AMFR Correction Fault
P1179 Maximum Negative AMFR Correction Fault
P1185 Oxygen Sensor Heater Circuit Open Upstream
P1186 Oxygen Sensor Heater Circuit Short Upstream
P1187 Oxygen Sensor Heater Circuit Short Upstream
P1188 Oxygen Sensor Heater High Resistance Upstream
P1189 Oxygen Sensor Heater Type 1 Low Resistance Upstream
P1190 Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1191 Oxygen Sensor Heater Circuit Open Downstream
P1192 Oxygen Sensor Heater Circuit Short Downstream
P1193 Oxygen Sensor Heater Circuit Open Downstream
P1194 Oxygen Sensor Heater High Resistance Downstream
P1195 Oxygen Sensor Heater Type 1 Low Resistance Downstream
P1196 Oxygen Sensor Heater Type 2 Low Resistance Downstream
P1199 Fuel Level Sensor Circuit Fault
P1201 Injector 1 Open Circuit or Ground Short Fault
P1202 Injector 2 Open Circuit or Ground Short Fault
P1203 Injector 3 Open Circuit or Ground Short Fault
P1204 Injector 4 Open Circuit or Ground Short Fault
P1205 Injector 5 Open Circuit or Ground Short Fault
P1206 Injector 6 Open Circuit or Ground Short Fault
P1207 Injector 7 Open Circuit or Ground Short Fault
P1208 Injector 8 Open Circuit or Ground Short Fault
P1313 Misfire Catalyst Damage Fault Bank A
P1314 Misfire Catalyst Damage Fault Bank B
P1315 Misfire Persistent Fault
P1316 Misfire Excessive Emissions Fault
P1317 ABS Rough Road Line Low Fault
P1318 ABS Rough Road Line High Fault
P1361 No Ignition Coil Activation Fault Coil 1
P1362 No Ignition Coil Activation Fault Coil 2
P1363 No Ignition Coil Activation Fault Coil 3
P1364 No Ignition Coil Activation Fault Coil 4
P1371 Early Ignition Coil Activation Fault Coil 1
P1372 Early Ignition Coil Activation Fault Coil 2
P1373 Early Ignition Coil Activation Fault Coil 3
P1374 Early Ignition Coil Activation Fault Coil 4
P1440 Evap System Purge Valve Stuck Open Fault
P1441 Evap System Purge Valve Flow 1 Fault
P1442 Evap System Purge Valve Blocked Fault
P1447 Evap System Purge Valve Open or Short Circuit Fault
P1448 Evap System Purge Valve Flow 2 Fault
P1508 Idle Speed Control Open Circuit Fault
P1509 Idle Speed Control Short Circuit Fault
P1514 Neutral Drive Load Fault
P1516 Neutral Drive Gear Change Fault
P1517 Neutral Drive Cranking Fault
P1607 Malfunction Indicator Lamp Short Circuit Fault
P1608 Malfunction Indicator Lamp Open Circuit Fault
P1620 Reprogramming Code Learn Fault
P1621 Serial Data Link Dead Fault
P1622 Repeated Wrong ECM Security Code Fault
P1623 ECM Security Code Fault
P1701 Transfer Box Line Fault
P1703 Transfer Box Line Open Circuit Fault
P1708 Transfer Box Line Short Circuit Fault
P1775 Gearbox Fault
P1776 Gearbox Ignition Retard Request Timeout Fault
P1777 Gearbox Ignition Retard Request Line Fault
Special Codes
As well as the standard codes each manufacturer has their own specific codes, and a unique header code/name from the ISO.
Rover specific header code names are 502 - 511
I don't have any information about usage on vehicles
Relevant codes could be
Rover 502 - 511
Lucas 850 - 860 CBS/ABS
862 - 863 Diesal fuel engine control
877 ditto
939 ditto
Wabco 121 - 125 Breaking systems
SAGEM ? 795 - 799 Engine management
?GEMS? 837 Chassis
880 On board electronics
There are 4 and 5 digit codes but none seem relevant to LR
Landrover specific diagnostic codes.
This list is the best I can find so far.
So don't bet your granney on it.
It duplicates the P1*** manufacturer codes
from the table above. The table is a
subset of the SAE standard published in
HS-3000 "On-Board Diagnostics for Light and
Medium Duty Vehicles Standards Manual". See
also ISO 9141 & 9141-2.
USING it may well be harmful to your vehicle!
so don't blame me when it all goes horribly wrong.
summary code extensive code
_________________ _________________________________________
P1130 O2 FT Limit AU P1130 Oxygen Sensor Fuel Trim at Limit *Codes* A U
P1131 O2 Lean AU P1131 Oxygen Sensor Engine Lean *Codes* A U
P1132 O2 Rich AU P1132 Oxygen Sensor Engine Rich *Codes* A U
P1137 O2 Lean AD P1137 Oxygen Sensor Engine Lean *Codes* A D
P1138 O2 Rich AD P1138 Oxygen Sensor Engine Rich *Codes* A D
P1150 O2 FT Limit BU P1150 Oxygen Sensor Fuel Trim at Limit *Codes* B U
P1151 O2 Lean BU P1151 Oxygen Sensor Engine Lean *Codes* B U
P1152 O2 Rich BU P1152 Oxygen Sensor Engine Rich *Codes* B U
P1157 O2 Lean BD P1157 Oxygen Sensor Engine Lean *Codes* B D
P1158 O2 Rich BD P1158 Oxygen Sensor Engine Rich *Codes* B D
P1171 O2 Lean A B P1171 Oxygen Sensor System Too Lean Fault Banks A & B
P1172 O2 Rich A B P1172 Oxygen Sensor System Too Rich Fault Banks A & B
P1176 Max+ FMFR P1176 Maximum Positive FMFR Correction Fault
P1177 Max- FMFR P1177 Maximum Negative FMFR Correction Fault
P1178 Max+ AMFR P1178 Maximum Positive AMFR Correction Fault
P1179 Max- AMFR P1179 Maximum Negative AMFR Correction Fault
P1185 O2H Open Up P1185 Oxygen Sensor Heater Circuit Open Upstream
P1186 O2H Short Up P1186 Oxygen Sensor Heater Circuit Short Upstream
P1187 O2H Short Up P1187 Oxygen Sensor Heater Circuit Short Upstream
P1188 O2H High R Up P1188 Oxygen Sensor Heater High Resistance Upstream
P1189 O2H T1 Low R Up P1189 Oxygen Sensor Heater Type 1 Low Resistance Upstream
P1190 O2H T2 Low R Up P1190 Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1191 O2H Open Down P1191 Oxygen Sensor Heater Circuit Open Downstream
P1192 O2H Short Down P1192 Oxygen Sensor Heater Circuit Short Downstream
P1193 O2H Open Down P1193 Oxygen Sensor Heater Circuit Open Downstream
P1194 O2H High R Down P1194 Oxygen Sensor Heater High Resistance Downstream
P1195 O2H T1 Low R Down P1195 Oxygen Sensor Heater Type 1 Low Resistance Downstream
P1196 O2H T2 Low R Down P1196 Oxygen Sensor Heater Type 2 Low Resistance Downstream
P1199 Fuel Level P1199 Fuel Level Sensor Circuit Fault
P1201 Inj1 Open or Grd P1201 Injector 1 Open Circuit or Ground Short Fault
P1202 Inj2 Open or Grd P1202 Injector 2 Open Circuit or Ground Short Fault
P1203 Inj3 Open or Grd P1203 Injector 3 Open Circuit or Ground Short Fault
P1204 Inj4 Open or Grd P1204 Injector 4 Open Circuit or Ground Short Fault
P1205 Inj5 Open or Grd P1205 Injector 5 Open Circuit or Ground Short Fault
P1206 Inj6 Open or Grd P1206 Injector 6 Open Circuit or Ground Short Fault
P1207 Inj7 Open or Grd P1207 Injector 7 Open Circuit or Ground Short Fault
P1208 Inj8 Open or Grd P1208 Injector 8 Open Circuit or Ground Short Fault
P1313 Mis Cat Damage A P1313 Misfire Catalyst Damage Fault Bank A
P1314 Mis Cat Damage B P1314 Misfire Catalyst Damage Fault Bank B
P1315 Mis Persistent P1315 Misfire Persistent Fault
P1316 Mis Excess Emiss P1316 Misfire Excessive Emissions Fault
P1317 ABS Rough Rd Low P1317 ABS Rough Road Line Low Fault
P1318 ABS Rough Rd High P1318 ABS Rough Road Line High Fault
P1361 No Coil Act 1 P1361 No Ignition Coil Activation Fault Coil 1
P1362 No Coil Act 2 P1362 No Ignition Coil Activation Fault Coil 2
P1363 No Coil Act 3 P1363 No Ignition Coil Activation Fault Coil 3
P1364 No Coil Act 4 P1364 No Ignition Coil Activation Fault Coil 4
P1371 Early Coil Act 1 P1371 Early Ignition Coil Activation Fault Coil 1
P1372 Early Coil Act 2 P1372 Early Ignition Coil Activation Fault Coil 2
P1373 Early Coil Act 3 P1373 Early Ignition Coil Activation Fault Coil 3
P1374 Early Coil Act 4 P1374 Early Ignition Coil Activation Fault Coil 4
P1440 Evap P Val Open P1440 Evap System Purge Valve Stuck Open Fault
P1441 Evap P Val Flow 1 P1441 Evap System Purge Valve Flow 1 Fault
P1442 Evap P Val Block P1442 Evap System Purge Valve Blocked Fault
P1447 Evap P Val Open,S P1447 Evap System Purge Valve Open or Short Circuit Fault
P1448 Evap P Val Flow 2 P1448 Evap System Purge Valve Flow 2 Fault
P1508 Idle Open P1508 Idle Speed Control Open Circuit Fault
P1509 Idle Short P1509 Idle Speed Control Short Circuit Fault
P1514 Neut Driv Load P1514 Neutral Drive Load Fault
P1516 Neut Driv Gear P1516 Neutral Drive Gear-Change Fault
P1517 Neut Driv Crank P1517 Neutral Drive Cranking Fault
P1607 MIL Short P1607 Malfunction Indicator Lamp Short Circuit Fault
P1608 MIL Open P1608 Malfunction Indicator Lamp Open Circuit Fault
P1620 Repro Code Learn P1620 Reprogramming Code Learn Fault
P1621 Serial Dat Link Dd P1621 Serial Data Link Dead Fault
P1622 Repeat Wrong ECM P1622 Repeated Wrong ECM Security Code Fault
P1623 ECM Secur Code P1623 ECM Security Code Fault
P1701 Transfer Box P1701 Transfer Box Line Fault
P1703 Transfer Box Open P1703 Transfer Box Line Open Circuit Fault
P1708 Transfer Box Short P1708 Transfer Box Line Short Circuit Fault
P1775 Gear Box P1775 Gearbox Fault
P1776 Gear Ignit Ret TO P1776 Gearbox Ignition Retard Request Timeout Fault
P1777 Gear Ignit Ret P1777 Gearbox Ignition Retard Request Line Fault
Post #323725 Fri Dec 02 2011 7:57pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Dont tell anyone but it seems Kyle's motor is easy to nick tonight Laughing
Post #323730 Fri Dec 02 2011 8:29pm
What the he'll is an ECM security code? RRS gone
Post #323822 Sat Dec 03 2011 5:17pm
Isn't it a way to jam an enemy's radar during an attack? Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #323827 Sat Dec 03 2011 6:04pm
They did,
But this BMW linked code must apply to the 3L Vouge
Do not think any BMW bits made it to the sport RRS gone
Post #323969 Mon Dec 05 2011 10:35am
rangehelper
Russia
P162300 Immobilizer Code Word/ID Number Write Failure
Challenge failed due to timeout
Check the circuits between the modules. Refer to the electrical guides. Check for network DTCs. Repair/renew as necessary. Clear the DTCs and test for normal operation.
Post #324036 Mon Dec 05 2011 7:15pm
garrycol
Australia
See a whole lot of codes here - use your browser search function to find the required code you require
http://www.permoveo.ltd.uk/tabid/123/Diagn...fault.aspx 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #324072 Tue Dec 06 2011 2:38am
Fab cheers I think that's enlightned me!
I've had a couple of occasions where when I turned the start key, everything and go's blank..like it's immobilised . then I try again and all is fine.. it's only happened twice since the cold weather (prob battery issue) and it's been fine since...I can only assume this was logged as a fault!
cheers everyone RRS gone
Post #324084 Tue Dec 06 2011 9:39am
