stephenw
| Dual Battery and UHF Antenna Mount | |
All, the mods continue. This weekend I added a second battery to power the Engel 40lt fridge, UHF radio and camping lights. While it's only a 48amp/hr battery, this type recharges quickly so suits our camping mode of normally only spending one/two nights in one spot. A quick drive and the battery is fully charged again. I'm yet to complete all the wiring. I plan to add an extra outlet down near the tow bar to connect to our off road camper trailer. This will allow the car to charge the deep cycle battery in the trailer on the move or when stationary, allow the solar cells on the trailer to charge the vehicle battery.
The second battery is separated from the vehicle system by a voltage sensing relay. This connects the two batteries when the main reaches 13.7 volts and separates them at 12.8 volts.
The UHF antenna is mounted on a Rhino Rack bar (the tracks are Rhino's as well - a LOT cheaper than the LR versions at AUS$150). The coax is fed down under the black finisher panel so it looks really neat. The connectors allow me to remove the roof bar. The connector, when not in use, sits in the track channel.
 | | Click image to enlarge |
Second Battery
Voltage Sensing Relay
Rhino Roof Rack and UHF Antenna Mount
Next up is the addition of HID or Zenon bulbs to the headlight units. As I didn't buy the LR bi zenons with the vehicle (AUS$2500), I plan to mod the current halogen lights. I have bought a 55w HID kit (AUS$270) and will fit next weekend. The LR system is only 35w (I think). I'm yet to make a decision on whether to upgrade low or high beam yet. I will depend on space within the headlight unit. Ideally, I'd like to do both (and therefore will have to buy another kit). I want to mount the ballast within the headlight unit. If this works ok, this has applicability to those with the bi-zeon from LR as the spots in these units is only halogen anyway.
Steve RRS TDV6, Stornoway Grey, Tasmod Sills, Active Rear Diff, AVN 6000 player inc DVD, Sat Nav, TV, Rear Camera and Front/Side Looking Camera, HDD Media Player, Parrot Bluetooth, UHF, Sat Phone, Dual Battery, Rhino Racks, Snorkel, ARB Air Compressor.
