Home > Wheels & Tyres > Defender wheels on L494 |
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 36 |
I asked a similar question a while ago, no answers.
Thu May 02 2024 8:00pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
There is nothing specific about big "Red" brakes, they are simply 6 pot brembo's painted red, some svr's and other models are painted Blue, others simply have the Land Rover logo on them, I think most of the later L494's had them one colour or another anyway, the wheels on the Sport will be 5 x 120 PCD, can't remember the bore diam offhand but I think it is 72.56mm though. There a few different offset's though depending on rim diameter/style etc. The option for 19" rims that fit over the 6 pot brembo's used to be very limited.
Thu May 02 2024 10:09pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
I'm not sure the L494 (at least at the end of its life) was even offered with 19in rims was it Col? 2012 SDV6 - it's missing a couple of cylinders
Thu May 02 2024 11:09pm |
Not sure either Wayne, should have stated that I was just referring to about 19" rims fitting over the 6 pots in general, could be the new defender 19" have enough clearance to fit over the brembo's, would have thought someone may have tried by now.
Thu May 02 2024 11:24pm |
Villager Member Since: 24 Aug 2023 Location: Blackburn Posts: 6 |
I chickened out and went for 20" Discovery 5 wheels instead. Just as well as there's very little clearance over the calipers even with those.
Fri May 10 2024 5:27pm |
