Home > General > Serious or not? |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Sounds like a battery or power supply issue. Low battery output can send "ghost" messages. TB would be the man to ask. Doesn't sound major though and it's under warranty so dont worry! Good Luck! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Mon Apr 16 2007 8:49pm |
Sounds pretty serious if Land Rover assist cannot get it to do anything at the roadside.......... these guys are usually pretty good at getting you going again when the electronics play up. I wonder if because of it's age and exceptionally low mileage it hasn't had the various electronic upgrades done at service time - are you the first owner of the car? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Apr 16 2007 8:51pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
I've had simillar problems... |
Mon Apr 16 2007 9:15pm |
Go on then Doc.., dont be a tease! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Mon Apr 16 2007 9:16pm |
I'm not going there |
Mon Apr 16 2007 9:28pm |
Spoilsport! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Mon Apr 16 2007 9:31pm |
YY Member Since: 11 Jul 2006 Location: London Posts: 23 |
No there's no previous owner, I just live in London and work close by so that explains the low mileage. The LR assistance guy was very surprised that he could not connect to the car, which doesn't sound great. He seemed to think it was a problem derived from the main electronic system not necessarily an actual suspension fault.
Mon Apr 16 2007 9:34pm |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Hello YY .... I too have a SEPT 05 [ 55 ] Supercharged - but I have covered an imense 15000 miles ... joking apart I had exactly the same problem - turned out to be a completely NAF - Dead Battery causing all my faults/alarms and eventual dead car - same as yours. Hope this is the case - as simple to fix. Car was only a few months old - if you do a search in " My RRS " section you will find all the details with regard to this. Cheers Martin " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Mon Apr 16 2007 10:46pm |
Thought that would be it MDP! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Mon Apr 16 2007 10:59pm |
Found it YY ... take a look through my experience http://www.rrsport.co.uk/forum/topic356-30.html
Mon Apr 16 2007 11:04pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
This oldie (but goodie) Tech Service Bulletin may also apply to your situation... Good luck!
Tue Apr 17 2007 2:54am |
Thanks a lot guys.. will update you. |
Tue Apr 17 2007 7:45am |
Good luck YY. Glad it's not looking serious.., as I suspected & hoped! MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
Tue Apr 17 2007 6:11pm |
According to the service guy, there is a fiber optic cable that links all the electronic devices in the car. There are 5 or 6 modules connected to this fiber optic cable. This cable was being "pinched" somewhere, and this leads to the disabling of all the modules. |
Wed Apr 18 2007 2:38pm |
