Home > Faults & Fixes > Inner door lock handle restricted movement
Stevepd
My NSR inner door lock tab has started to not move fully when you lock/unlock the car. If I lock the car I can see the tab goes flush with the handle and all is as intended. When I unlock the car the tab only moves outwards a little, enough that pulling the inner door handle won't open the door. A little tweak and you can open the door. The door can be opened from the outside no problem.
Anyone had this before. There's only the 2 of us so the rear doors are not used that much, but it's become apparent now.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #637064 Sat Nov 04 2023 12:32pm
NoExpert
Door latch modules are failing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637065 Sat Nov 04 2023 1:22pm
Farmer Chalk
As above….
You need to change the door lock module … otherwise one day you think you have locked your car but that module will not have pulled the locking mechanism and thus that door will remain unlocked and easy for anyone to enter your car..
Really really common fault.. I’ve replaced 3 of the 4 on our car and one of them twice..
Post #637136 Tue Nov 07 2023 10:10pm
Stevepd
Thanks to you both for replying, most helpful. Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #637152 Wed Nov 08 2023 5:06pm
Farmer Chalk
The locking module is effectively the door lock mechanism but where it gets complicated is that the mechanism is driven by two scalextrix size electric motors which start to fail over time.. the end up not strong enough to close the levers.. hence your problem…
They are relatively simple but fiddly to change..
Post #637153 Wed Nov 08 2023 5:22pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Just looked at a video on removing the door cards. You are saying its the lock unit thats failing rather than the electronic module....is that right?
You also imply that you can replace /repair the motors yes/no.
Any idea why the previous owner bought two of the cables linking the lock to the handle.
Thanks for your efforts Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #637165 Thu Nov 09 2023 9:58am
Farmer Chalk
Have just pm’d you..
Yes it’s the door lock.. I don’t bother changing the motors as it gets fiddly.. I just replace them complete…
The reason the previous owner bought new cables is that he probably snapped the small white retaining clips by just pulling them off.. they have small white tongues which clip into place on the door lock
Using a small pick you need to carefully release them then lift the cable away rather than just pulling them and breaking the clips..
Post #637166 Thu Nov 09 2023 10:18am
Pistnbroke
Many thanks to both who replied ...job for the warm weather ..I sit in the front !! Always listen to old people or when they die you will live on in ignorance.
Post #637167 Thu Nov 09 2023 10:22am
NoExpert
Both of my rear latches need to be replaced as well. The hardest part is probably getting the window regulator out of the door. After that it’s not too bad. Connecting the cables is a fun exercise in dexterity. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637170 Thu Nov 09 2023 2:37pm
Pistnbroke
having had a lot of experience with Jaguar door locks eventually replacing the whole thing with a new Chinese system for £20 I just raise this question.
The only thing connecting the door lock to the opening lever is the cable so if the lever bit is not working right then is it not a cable problem ...stretched maybe or are you saying the motors in the locks are not pulling on the cable sufficiently strong enough? Always listen to old people or when they die you will live on in ignorance.
Post #637171 Thu Nov 09 2023 3:02pm
NoExpert
Think more as the lock lever is just an indicator. The mechanism is the latch. If the mechanism isn’t working correctly then the indicator won’t show correctly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637174 Thu Nov 09 2023 5:25pm
