Home > General > Hi guys new owner questions appreciate any help
jorgefrankie
hi guys
looking forward to hopefully owning my first RRS next week!
I have reserved a car to collect after weekend, its a 2014 HSE DYNAMIC 3.0 SD V6, found a health check in the glove box from 6 weeks previous and had the following on it would any of these be a reason to worry? thanks for any help in advance.
battery 2018 down 100amps
arc pipe misting from arc pump to main pipes
drive belt tensioner starting to rust
n/s/r handbrake motor startin to crack
Post #615195 Sat Jun 26 2021 9:50pm
Would at least get them to replace the H/Bake motor, assume they mean plastic housing cracking could lead to water ingress and failure in the future around £200.00 for a new one.
Post #615196 Sat Jun 26 2021 10:13pm
jorgefrankie
thanks for the reply Col Thumbs Up its priced quite well so would be happy to get the rest done myself soon as I'm the owner, is there anywhere in the northwest anyone can recommend for the work to be carried out
Post #615197 Sat Jun 26 2021 10:17pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Re: Hi guys new owner questions appreciate any help
jorgefrankie wrote:
hi guys
MY 14.5 - I've had the arc pipe misting issue, replaced the pipe from the pump to the first joint, seems to be from where the alloy pipe is crimped to the high pressure flexible section. Never lost any fluid but annoyed me so I replaced it. Easy job to do, if you buy the pipe it comes with the seals for both ends so don't go buying those separately.
Post #615219 Sun Jun 27 2021 8:38pm
