Home > Off Roading & Green Laning > Goodyear Wrangler Duratrac 255/65/19 or 255/55/19
robtheranter
Scotland 2006 Range Rover Sport Supercharged HST Zermatt Silver
New to this so be gentle.
I could do with some advice regarding some off road mods I'm carrying out on my RRS Supercharged.
I've fitted a set of adjustable Johnson rods which give me 50mm lift in preparation to fit a set of Goodyear Wrangler Duratrac 255/65/r19s on Disco 3 rims, I've done a little bit of homework and everything should fit with a little bit of clearance.
Has anyone fitted this wheel / tyre combination ?
What will the larger sidewall drive like on tarmac ?
I have the option of the same tyre at 255/55 but think the 255/65 with more rubber on the sidewall will perform better off road and look better, would I be right ?
Thanks in advance , Rob.
Post #604164 Sat Sep 05 2020 2:26pm
HughN
Wales
Hello, Rob.
I fitted Duratrac tyres on my L320 and have had three punctures whilst off-roading - all of which were in the sidewalls. I'm not impressed and other people have told me to send the pictures/tyres back. Don't get me wrong, they grip well and clear the tread nicely but the sidewalls appear to be very vulnerable to rocks and to stones in the sides of ruts. I now take two spare wheels and tyres with me.
Not too noisy on the road.
HTH
Hugh
Post #604170 Sat Sep 05 2020 6:58pm
robtheranter
Mostly peat bog and deep mud use for me so should be ok for punctures
Post #604197 Sun Sep 06 2020 1:13pm
Pufftmw
Just seen this. Won't the 65 profile be too much for the speedo etc? 255/50/19 is the OE size iirc but /55 is within tolerance but /65 would be a bit too much. I think that the way forward is to get 18" rims for 265/60/18 or 255/65/18.
If you're not worried about sidewall punctures, there's also no benefit I would have thought from a 65 profile.
Post #607317 Tue Dec 08 2020 2:29pm
Buckster
265/65/18s here Wink 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #607342 Tue Dec 08 2020 11:49pm
biasbilt
I’ve just fitted 19x7.5j ET 47 wheels from a 2015ish RR, fitted with the Duratracs, no lift, and standard Discovery 4 sized brakes. Plenty of clearance on bumps at full lock both ways - may be 1” minimum, so room for slightly bigger tyres if needed. I can get some specific measurements tomorrow if you want them.
Compared to the 6 spoke Discovery 3 19x8j ET53 rims, they have a tiny bit more offset which you’d think would be negated by being narrower but they look like they fill the arches better. Theoretically, with the change in offset, it does affect the geometry slightly, but you can’t feel it/tell driving.
Noise wise, I can’t really tell the difference from a set of road tyres, with the engine (tdv8) possibly being dominant and overall certainly quieter than my old D3 on road tyres.
Can’t tell you about offroad performance as it’s not been tested yet, but reputationally good. Only thing I’d say is that having inflated them to the same pressure as the 255/55r19 road tyres on the D3, they look like they need more, but that be the slightly narrower wheel - I’ll be experimenting with this over the next few weeks, with a temperature gun.
Finally, they look a lot better, filling the arch much better than the 275/40r20s that came off it! They also correct the speedo, which reading 75 but doing 70, and is now reading 75 and doing 74 (tested where conditions allow) Thumbs Up
Post #612204 Thu Apr 01 2021 11:11pm
jk3528
18” steel defender wheels with 255/70/18 Michelin latitude tyres that’s at access height overall 32.1” dia
Post #630767 Sat Feb 11 2023 12:30pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Being the supercharged with Brembo brakes I thought the smallest wheel was 20inch you could fit.......???
Post #630776 Sat Feb 11 2023 8:13pm
83series3
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
I looked at downgrading my 2007 tdv6 down to 18 inch wheels, but then found that I had the brembo brake option installed from factory (courtesy of Simon and PowerfulUK.com, who looked up the build sheet for me) …. Apparently you can get away with 19 inch alloys with the brembo option, but no lower.
@biasbilt - your wheels / tyres look really good!
@Lrstaylor - hi from another Kent RRS L320 owner
Post #630944 Sun Feb 19 2023 7:11pm
83series3
Oh crikey - just read another post on a different thread, so looks like some 19 inch alloys fit, and some don’t …. Sheesh ….. offset research time, before more expensive mistakes are made Laughing
Post #630947 Sun Feb 19 2023 7:55pm
Buckster
Set of 18s here on Brembos Wink 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #630951 Mon Feb 20 2023 9:58am
Pufftmw
But Buckster you're running Compmotive PD1881s... Lovely but not cheap!
Post #630959 Mon Feb 20 2023 5:10pm
Tuffant do an 18 inch steel at £720 for 4 if anyone wants that sort thing. Designed for the D4 including the SDV6 so presumably would fit an RRS too. Be worth checking with the UK supplier to make sure they'd fit, of course.
https://noroadclub.com/collections/tuffant...9122407579 2012 SDV6 - it's missing a couple of cylinders
Post #630968 Mon Feb 20 2023 5:54pm
Pufftmw
I think they are what HughN has
Post #631077 Thu Feb 23 2023 6:57pm
