Home > Maintenance & Modifications > Air con |
JohnBlueSport Member Since: 28 Jun 2019 Location: ayrshire Scoltland Posts: 25 |
Hi, Got a problem with the sport. Recently aircon blowing slightly warm air when switched on, took it to the garage for regas, they said it was full and holding pressure, but still blowing lukewarm air, anyone had the same issue and how they resolved it or is it a case of just replacing everything in hope of fixing it, just cold air is needed in this weather |
Wed May 13 2020 6:57pm |
Was it a specialist who tested the gas |
Thu May 14 2020 10:48am |
Had it checked by Kwikfit if that helps, checked last night, can here the revs drop when aircon is switched on |
Thu May 14 2020 3:42pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4405 |
Air con pressures need monitoring, to see if the compressor clutch in engaging and disengaging, and also for pressure increase and loss
Thu May 14 2020 3:58pm |
Thanks might bite the bullet and take it to land rover, |
Thu May 14 2020 4:21pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
let us know of the outcome mate...seem to have a similar issue RRS TDV6 2010 |
Tue May 19 2020 6:41am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Personally I would find an air con specialist in the first place. LR Main dealer will charge handsomely even before looking at it.
Tue May 19 2020 7:05am |
